First Time Running the Quarter Mile (14.0@99.55MPH)
I guess you could say we had a mini meet at Rockingham tonite for T&T.
Here are a few of my better runs.
BEST RUN (ET)
R/T-------.321
60-------2.176
330------5.982
1/8------9.121
MPH-----77.24
1000----11.816
1/4-----14.086
MPH----99.55
MODS are listed in my sig except I peiced together a custom "Ram Air" intake through the drivers side headlight. I forgot zip ties so it kept falling down so I never got the ram air effect, just cold air from where the headlight should be.
A few other runs
R/T-------.494-------.284-------.350
60-------2.164-------2.211-----2.317
330------5.989-------6.040-----6.159
1/8------9.144-------9.193-----9.304
MPH-----78.28-------78.30-----77.17
1000----11.834------11.886----11.999
1/4-----14.111------14.165----14.267
MPH----98.29-------98.21-----99.60(Best Trap)
Not bad for a 3.0 with USIM no ECU and no tuning on street tires
BEST RUN (ET)
R/T-------.321
60-------2.176
330------5.982
1/8------9.121
MPH-----77.24
1000----11.816
1/4-----14.086
MPH----99.55
A few other runs
Thanks guys. Im not sure what my biggest power adder is. I think my car just responds well to mods, or the ones I have just work well together. The headers and Y are the infamous stone racing ones. Yes, I was running the buzzsaws with BFG Touring T/A tires at 25 psi. Hopefully next time with an excellent launch and perfect shifting I can hit 13's!!!!
One more quick question.
Where did you have the mainfold ported and honed and how much?
Originally Posted by zack342
You just may, you may want to try your stock wheel tire combo as well since the weight difference may pick you up a couple 10th's.
Excellent times. Go to www.wunderground.com, scroll down to weather history, click it, and then find out what the barometric pressure, temp, dewpoint, and relative humidity were at the time you made your runs. That and the track elevation, this way we can figure out the DA. I would go there right now and find out for you but I'm on dialup and that website does not work on dialup AT ALL lol.
Looks like ceasars got some competition lol. I think the p&p helps response if anything, I did it to my mevi and noticed it picked up off the line a little better then my usim, but after that it sucks till 5k and starts to pull again, but thats just the nature of the mevi. Im doing the same to my usim and lower to see if it really helps, no other mods. Who knows, and its basically free if you already have a dremel.
The time on the slip says 11:08 pm but their clock had to be off because they shut down the track at 10:15. Im pretty sure I made this run around 900-920 so heres the info:
BARO: 30.05 Hg
Temp: 53.6
Dew Pnt: 33.8
Rel Hum: 47%
Elev: 375ft
BARO: 30.05 Hg
Temp: 53.6
Dew Pnt: 33.8
Rel Hum: 47%
Elev: 375ft
Do you have a dyno? I'd like to see what kind of power you're making. Good times but they seem a bit quicker than I'd expect for your mods. Of course your DA is gonna be pretty good too.
The DA at that time was 44 feet. DA is density altitude, basically with regards to racing it is used as a measure of how "good" the atmospheric conditions were for racing. 44 feet is a very good DA. It basically means that the temp, humidity, and pressure of the air you ran in was the same as running at a track 44 feet in elevation on a standard day.
It's good for comparing your runs to other people's runs, and also to other runs you will make. If you run at the same track again you can compare the DA from this time to the next time to see how the atmospheric conditions affected your runs. If you run way slower next time and then find out the DA on your next runs is 1500 feet, then you know why. If you run way faster and find out you've got a -1000' DA, you know why. It takes alot of the guesswork out of "why did I run so much slower/faster than last time?"
vnt
Ahh, thanks for the info. How is it calculated?
http://wahiduddin.net/calc/calc_da.htm
Damn that's fast - especially so for a natural breather with almost no mods...Caesar does have some serious USIM competition. I thought you were blown or turboed myself when I saw this thread.
yeah I hit the 14.08 the next run after you left. When we got ready to leave I remembered you had the 14mm socket to bolt down the passenger seat, so my friend rode home on hand tightend seat bolts.
those where about the best conditions Ive ever seen at Rockingham as far as track temps and track prep. Nice times, I left right after your 14.1 run right after you gutted the car.
00 VI, ECU, and some tuning on slicks you have a car deep into the 13's.
Originally Posted by 95BLKMAX
Wow this is amazing for your mods. Congrats, and
on u going to the dyno. I must know what kind of power you're actually putting down.
on u going to the dyno. I must know what kind of power you're actually putting down.He is probably not putting down that much power. Probably 185ish whp and 190ish whtq. It's just the combination of good driving, great weather, and weight reduction.
fantastic though, another example of 4th gens on the move !
Oops..sorry Caes - didn't see that part. USIM? You and I must be about the only ppl with that still in our cars...
BTW - pm or email me if you get the chance bro about how that thing is going.
well im slowly working on putting an end to that, was quoted 5,ooo bucs for a vq35de, enough to put me off and just go with the OOVI swap. got to have it completed by NOV.
blue did you do your run with those big chromies ? dang dude !
No, I didnt run on the "chromies" had the stock buzzsaws on. Those 18's are too heavy. I am about to leave N/A and install nitrous in the next few days. I went just to get a base of what my car runs as a natural breather. Lets just say it did much better than I thought it would. I guess if I were to get an ECU Id be running with you.
And no ECU huh? Great runs
The 95's were tearing it up.
