02 Motor Mount Question?
3.5 Motor Mount Question
I noticed that the motor mount that's shown in the picture looks a little strange to me, and I wanted to run it by the group. I wasn't able to get a very good picture of it, but basically the rubber part looks sort of squashed at the bottom. It looks a little like a tire that's low on air. It's not clearly visible in any picture that I snapped, but at least you can see the mount I'm referring to. I'd appreciate hearing back from anyone who knows if it's normal for this mount to look slightly squashed, or if the rubber part should be uniform and mine has gone bad. I have that annoying slight vibration at ~2000 RPM that I've not been able to track down.
Thanks everyone!
Thanks everyone!
I'm not sure what its supposed to look like, but I'll see if I can snap a few pics of my side mounts later today or tomorrow.
My hunch is that it shouldn't look like a flat tire....
Thanks - I'd appreciate if you could look at yours. If you pull back the rubber ring that sort of covers the end of it you should be able to see fairly well how it looks. I just couldn't get that to show in pictures.
Anyone on the forum replace this mount? You should be able to tell me pretty easily how it is supposed to look.
Thanks to anyone who has input on this!
IIRC, these side mounts don't really go bad because they aren't under as much stress as the front and rear mounts, which is why not many people have had to replace these. At least, not yet.
Originally Posted by HotshotVQ35
IIRC no one makes side mounts, only the front and rear
Here is what mine looks like:
[IMG]
[/IMG]
This car has about 55k miles on it if that helps. BTW, mine looks like a different part than your's for some reason. Maybe it's just the salt buildup on your's?
[IMG]
[/IMG]
damn my rear one f@#ked everytime i shift into second or third my shiznit feels like a maracca...LOL one question i know the rear and front one cost 83$$ is it hard to do it urself... i have an engine hoist and everything....they sell side ones but there rare to find...
Busi87- its easy to install...the hard part is to find someone that has a large enough adaptor to press out the old mounts....you might have to go door to door hunting for a mechanic that will do these for u...unless you already know someone with a large enough adaptor to press out these old mounts
Originally Posted by Puppetmaster
I haven't actually checked yet, but besides the fact that it looks off, is there anything else that leads you to believe that it may be bad? Is the liquid filling leaking? Does the motor move excessively on that side?
The other dealer said it's my hood latch out of adjustment. Neither one was covered by my exteneded warranty and since I don't believe either diagnosis I refuse to pay to try them.
I was just poking around for anything that looked abnormal and thought that mount looked a little strange, but I have nothing to compare it to so it may be normal. There is no fluid leaking and the motor doesn't move around under throttle. I'm just trying to rule this out as a problem (It would be awesome if it was the problem and I could solve that vibration!).
Thanks for posting the pics!
That is the same part as mine - yours is just salt-free, and you have grey paint while I have black. Is the rubber part of your mount cracked? In the closeup, it looks cracked to me.
Originally Posted by kvk2003max
Nighthawk750, do you have a auto or a manual transmission. The auto transmission engines have electronic controlled mounts, and the engine mounts on my 2003 GLE auto looks exactly like yours. I am not sure if they are fluid filled though.
I used to have a 6-speed Acura Legend that had a pronounced vibration at exactly 2,200 rpm. I always thought it was just how the car was but now I wonder if it had a broken mount. Oh well, it's someone else's problem now.
vingodine
45
May 21, 2016 12:46 PM
sdotcarter
Sep 2, 2015 09:53 PM
