bolt on so tight...suggestion for substance to loosen it up
trying to unscrew the two bolts that hold the caliper mount on so I can get my rotor off and those things are on there solid. Any ideas of what I can use to loosen them up
Just to make sure, your turning it in the right direction right? because I've done that to myself before. and oh yeah everything they said or some wd-40 works well....and i was able to get mine off with a regular ratchet
PB blaster, heat, box wrench and a hammer, or just beat near the bolts with a hammer to loosen the rust up, beating on the bolt itself (careful here), or a combination of all of the above plus plenty of cursing should do the trick. Next time you reassemble, dip the bolt in motor oil first, make sure to get some oil or grease into the bolt hole itself, then proceed as normal.
wd40 failed
old school ratchet failed
going for PB blaster and buying a breaker bar tomorrow
those are the two bolts you have to get off to the get the caliper mount off and inturn get the rotor off so I can get to the wheel studs correct?
if wrench and hammer doesnt work, hammer a lil in the direction to tighten it. keep doing it back and forth and it might break free. and if you plan on using heat, try not to damage the brake lines.
nope
I think I was turning it the wrong way in the beginning and the tools I have are ancient
I got to finish this tomorrow so I can get to the maxima meet and not miss it for the 3rd time in a row.
Originally Posted by aw89maxSE
wd40 failed
i don't know if u'd want to dip them in any oil when reinstalling...i mean u don't want them to come out all that easily considering the minor safety role they play...maybe just a dab of anti-seize
air ratchet FTW!!!
Finally got them out. Put the new studs in and all that's that left is finding out how a piece of the brake shield isn't letting me get the rotor back on, but I can figure that out after work.
Thanks guys
You never mentioned what you tried to loosen it with. A little 12" 3/8" ratchet isn't going to produce much torque unless you are Hulk Hogan.
1/4" breaker bar and a 6 point socket. Cheater pipe if necessary.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
