1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
DR mod?
Old Mar 24, 2006 | 03:46 AM
maximaownsyou's Avatar
DR mod?
i plan on going to the track in a few weeks for the first time and im trying to research some good techniques. i hear alot about the DR mod? what exactly is that? what times should i expect. i have a 2002 gle 3.5L with a berk intake, free flow test pipe, magnaflow exhaust, no resonator, pure synthetic royal purple fluids, 18 x 7.5 lightweight rims
Old Mar 24, 2006 | 06:16 AM
konak85's Avatar
IT is the drop resistor mod, it makes your tranny shift rougher and harder. You can read up on it on the General Max or 4th gen fAQ's.
Old Mar 24, 2006 | 07:02 AM
NmexMAX's Avatar
dot dot dot ...
I've never heard of such device? How does it work, and what are the gains?
If I have I/H/B/17*/ and drag suspension, how much faster will I be with this mod? Last time I did a 13.78 @ 100.48 mph....
Old Mar 24, 2006 | 09:01 AM
C MAX's Avatar
i dont know if it makes you any faster but it helps the tranny last longer. normally in between shifts you have lag for comfort so when you disconnect the drop resistor it shifts firm and strong during hard acceleration. it may help improve times because you are now getting fuul strong shifts instead of lazy ones which results in a slight increase in 1/4 times. i tried the drop mod with a micro switch at first but mine kept melting so i resorted to when i go to the track i just unplug it before i run and it works just fine. i use to have the stage 3 vb but when i got a new tranny i never put it back because some times it would get on my nerves so i decided to wait till summertime but this way works so good i might leave it because the car is nice and smooth until i wanna race. this and a a tranny cooler will prolong the life of your tranny
Old Mar 24, 2006 | 09:07 AM
NmexMAX's Avatar
dot dot dot ...
The last A33B that tried this had worse results in the 1/4.
Old Mar 24, 2006 | 09:33 AM
C MAX's Avatar
thats why its really beneficial for FI or nitrous guys. where if before you were losing pick up from the tranny lagging this will give it back. i guess its equivalent to a undrive pulley it doesnt give more hp but makes the car faster. but its real function is to preserve tranny life.
Old Mar 24, 2006 | 09:37 AM
NmexMAX's Avatar
dot dot dot ...
I know that, but the OP doesn't, nor does he have either.
Old Mar 24, 2006 | 10:02 AM
hmmm ok thanks but what times should i strive to hit?
Old Mar 24, 2006 | 10:08 AM
NmexMAX's Avatar
dot dot dot ...
Who cares just go and see you get. When you try for times you will be dissapointed.
Old Mar 24, 2006 | 10:18 AM
C MAX's Avatar
yeh just get out there and practice. those 18 in are gonna slow you down a little.
Old Mar 24, 2006 | 03:17 PM
ajcool2's Avatar
Heres the link for the DR mod. http://forums.maxima.org/showthread.php?t=285482 I've run my fastest times with it unplugged. I dont have it hooked up to a switch because I'm not really good with wiring things. CMAX thats the reason I didnt get the vb mod also I didnt want the car shifting hard all the time just when I race.
Old Mar 24, 2006 | 03:57 PM
tedo007's Avatar
faster than you think
i tried it alot of times in my car. it doesnt help me at all. i ran 9.8 1/8 mile both times with or without
Old Mar 25, 2006 | 02:27 AM
Jime's Avatar
The DR mod will help save your trans if used with a WOT switch because it shifts quicker and saves the clutches.
It will not make your car quicker unless you are putting down some serious power ie minimum 250 to the wheels and higher.
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
