Angel eye size?
thats a good question...lol...
i also have one quick question....i saw thhese LED angel eye rings in advance auto parts, they were like 14bucks or something, and i was wonder if the size was the same, would i be able to hook those up....
just a thought....someone should give it a shot....i might if the size is good...
huso
huso
Originally Posted by skierxx5556
I dont plan on using LED's but something else. I need to know the size of them first lol...
i;ll guess...
is it one of thsoe things that ppl use for interior and ****, it glows, they have different colors...its like a glowing wire....
damm i never thought of that...
let us know what your using..
huso
I was afraid someone would flame me if I asked, and I'm not ready to do the mod yet so I was waiting, but I would also like to know the ring size in mm, I was looking at these on eBay...
http://cgi.ebay.com/ebaymotors/BMW-E...50627118QQrdZ1
i dont think that it has to make all the way around....
just the sides and the lower part, the upper part of the circle doesnt have to "glow" so i think that those would work, and they seem really cheap and someone should try it, I am not going to be first one to lol...good luck on that....
huso
huso
If you're planning doing custom angeleyes with Elwire please don't waste your time and money....been there, done that.... check this link and you'll see the results http://public.fotki.com/saucisse/custom_angeleyes/ picture 1 was with the flash ''on''
and picture 2 and 3 w/o.
I'm doing another try with CCFL rings from computer fans (can be found for like 12$)....these are the same rings used on original DDE's powered by a 12V DC inverter and output is like +- 240V A/C depending on the inverter you're using. I will also install as a safety for the inverter, a 12V regulator for the power input since the alternator/battery output can go over 13V.
I know this may sound ''ghetto'' but kind of fun when you have time to kill
and picture 2 and 3 w/o.I'm doing another try with CCFL rings from computer fans (can be found for like 12$)....these are the same rings used on original DDE's powered by a 12V DC inverter and output is like +- 240V A/C depending on the inverter you're using. I will also install as a safety for the inverter, a 12V regulator for the power input since the alternator/battery output can go over 13V.
I know the 140mm should fit the high beams....for the low beams, I'll see once I'll have re-open the headlights...maybe I'll use the same 140mm since those are the larger available and try to custom fit them in place....we'll see...
For the smaller ring of the fan, I've just custom fit one on the ignition key light ring!! Just too bad I did not had the my camera at the time we did it
I like that idea for the ignition key ring. I think im gunna have to give that a try too!
What do you plan on using as a regulator?
Originally Posted by spencediggy
where u at the dogalston meet? if so, i wanted to ask you bout them angel eyes. what kind of glue you used to put the angel eyes on?
Bump. Anyone have a set that they can measure for me???
"The kit can also be applied on other vehicles but there is no specific installation guide can be provided for vehicles other than BMW. As long as there is a way to take the headlight lens off and the ring can fit into the headlight (outer and inner diameter of ring are around 13cm and 11cm respectively), these angel eye rings can work in your headlights!"
knight_yyz
Nov 1, 2015 01:34 PM
