apexi filters.
apexi filters.
Stupid question but the apexi website doesn't really say much about this. I'm assuming this is a reuseable filter. How do you clean it? Just a blast of air?
It's about 30K miles...IMO the filter is not worth it. I've run stock paper filters, K&N drop-in filter, APEXI cone filter, and now K&N cone filter.
The best overall value IMO is the K&N filter. I know people are wary of it because of the oil, and honestly I was too a few days ago when I pulled my intake plenum off. BUT...after further investigation I found oil residue in my intake tube (Injen CAI) which leads me to strongly believe the oil residue in the intake plenum was a reseult of the blow-by (damn air regs).
Originally Posted by chr0nos
do you guys know the average lifetime of an apexi filter wiht berk intake, and where to find cheap replacements?
I just ordered the berk intake with an apexi filter. Ive tried k&n on an injen intake when I had my mazda 3 and I never had problems but with an intake being this short, I didnt wanna take any chances on oil getting on my MAF.
I'm on a MAf adapter and an Ebay cone filter, The biggest problem with this set up was supporting the cone, easily corrected by keeping the top support braket (for the air box) on the strut tower and a long zippy tie.
K&N is the worst filter you can put on. I rahter have a stock nissan filter then that oily pos filter on my max. I have the apexi filter and the reason it is the best because it is not foam which can tear up and get sucked in, it doesnt have oil in it like K&N and you have to re-oil the filter. yes the apexi is paper but that is a good thing. lifespan on them is 30k and then toss them. i bought mine for $70.
I have never had any problems with any K&N filter I've had. I've been using them in diff forms since 1998. If someone is a total noobie and re-oils them improperly, you will have problems. But really, it's nothing an 8th grader couldn't do
On this car alone, I've had a K&N drop in for 30k miles and a K&N cone with the Berk intake for another 20k, and have had no issues whatsoever. I'm still using the original MAF that came with the car. I don't see why people think its so bad.
Ok, I love to spend money on my Maxima, but this just seems stupid. I buy her expensive oil, expensive antifreeze, expensive ATF, and expensive everything else, but I'm not going to drop $70 for a new air filter every time mine gets dirty. I'll just properly clean and lightly re-oil my K&N.
Originally Posted by timmy g
I guess I'm worried I'm a total noob, so instead of re-oiling my K&N i just replace it instead, after all they're still relatively cheap. I don't feel like taking a chance since our MAF'S are soo damn expensive, and so damn fussy! Apexi are good filters, but man the price is crazy for a throw away. Does anyone have any experience with AEM filters? They are also dry filters and I am thinking of switching over to these!
Originally Posted by spiromax
If you're comfortable with an oiled filter, but you're afraid that you'll mess up when you clean it and re-oil it yourself, you could always buy a new oiled filter every time yours gets dirty. Then you can sell your used one at a discount to somebody on the Org who is comfortable with cleaning and re-oiling his own filters. That way you can effectively reduce the cost of new reusable filters by getting some money back from your used ones.
All I know is from experience and after pulling my intake with over 75,000 miles on a K&N filter and seeing NO OIL RESIDUE inside I find your statement hard to believe.
Been running K&N for 15000 miles reoiled twice and no problems. If you follow the re-oil directions and not bathe thenm in oil you are fine. If you go to frankencars web they have an FAQ about K&N versus Apexi. They state Apexi through dyno's have proven a 3.5 hp advantage over maxima. Keep in mind though the apexi are roughly 50 dollar more and businesses are in it to make money. They also state life is 30-50k depending on climate. I stick with K&N because it is cheaper and I have a 2000 the MAF on 2000-01 are not as sensitive as you lucky ones with the 3.5.
The APEXi filter is the best choice for us Maxima owners, mostly because our MAF's are so g0dd@mn sensitive to Oil/dirt. K&N filters have a lot of oil in them, and being that the APEXi filter is a dry element filter you should be safe.
Part number 22680-6N200 is no longer sold at most dealerships. If you're a 2002 owner with a failing 22680-6N200 MAF sensor, you will be given the newer 22680-AM600 sensor if you ask for a replacement. If you're upgrading from the 22680-6N200 to the 22680-AM600, you should also get an ECU flash upgrade. If you don't want to buy an expensive 22680-AM600 sensor, you can buy the cheaper MAF sensor from a 2001 Maxima and simply reuse the temperature sensor from your stock MAF sensor housing (on 2000 and 2001 Maximas, the IAT and MAF sensors were not in the same place).
This is a long-standing myth that K&N oil filter = oil in the intake and throttle body.
People...before you make blanket statements you need to do some searching and find the facts.
lol.. 30k? umm im way past that.. haha.. by double WOW...time for a new filter.. i keep putting it off.
but yea i love the apexi.. used to have k&N.. got the apexi because i was soo afriad of a failing maf.. failing maf = like 4-500 dollars.. apexi filter = 120 dollars...
intake = cheaper in my book
Originally Posted by foodmanry
Based on the feedback from other Org members, my own experience, and K&N filter studies (along with some independent studies), the oil issue only comes into play if you OVEROIL the filter. If the filter is OIL CORRECTLY you will not have issues.
RTFM, and everything will be all right.
Originally Posted by 808MAX-SPEC
You can get a new MAF for about a $100.
Where???????????????????????????????????
This thread also has some info and good pics of the procedure. It is very easy, especially if you're replacing your MAF sensor anyway.
Btw... I just became a donating member today, and I LOVE being able to search. Now I know why Puppetmaster is always searching for other people and posting hundreds of links to old threads.
Originally Posted by OrigMax
Apexi is a great Air filter. Breath well and make hp especially on a turbo car.
i have over 50000 miles on my car with a k&n filter and berk intake.i have not had any problems with my maf sensor and the car has over 74000 miles on it!wish i could say the same for the tranny ,that had to be replaced last year
Originally Posted by n3985
Unfortuantely Apexi has closed the US Operation so I could not pull this statement from their web site.
http://www.apexi-usa.com/
But Frankencar has something on their web site. They sell the Apexi filter.
http://www.frankencar.com/products/apexi.htm
Too bad the Apexi filter is NOT A LIFETIME use filter as they claim it to be. The manufacturer states a limitation on the usage to somewhere around 40,000 miles.
I posted the link to show the Apex'i filter's filtering ability, and obv. nothing is lifetime warranty.
True...but as stated above, no one is arguing the filtering ability of Apexi. The debate lies in is the Apexi filter worth the added cost? But of course that all depends on the person.
Good for you. But that may not be the same sentiments for other people on here.
As stated before...its all a matter of personal choice and what value people put on the particular filter.
Maxima_Joe
Nov 25, 2015 08:19 AM
97_GXE
20
Sep 17, 2015 08:12 PM
