In need of rear exhaust...what should I get?
Well, I was driving today and I heard a loud muffled noise underneath my car. It turns out that the clamp/joint where the rear muffler pipe meets the intermmediate pipe is cracked and has a slight hole in the rear pipe. The stealership wants $350.00-$400.00 for a new Nissan one. I know the OEM's are much quieter than the aftermarket ones. But, I was wondering what's a good aftermarket brand muffler which is as good as the OEM, or as quiet as the OEM? Which ones should I stay clear away from? What do you guys suggest I get, or had experiences with? I'm not looking for performance, but at this point it really doesn't matter since I am in need of one ASAP. I don't feel like dropping that much money on a Nissan OEM. Thanks!
Originally Posted by CanadianAlien
Does your flange look like this:?
I had your same problem MIXX, and I replaced mine with a Bosal muffler.
It cost me 280 installed, and taxes in (CDN).
Originally Posted by MIXXMAX
Why didn't you just buy the part online and install it yourself? It's very simple. Just a few bolts to loosen and then re-install.
Originally Posted by Puppetmaster
You forgot to mention that the rear has to be jacked up about 2 feet in order to wriggle the rear section off and on.
Thanks, but yeah, I just thought that it was a "given" whenever you work underneath the car.
Have you actually tried swapping out the rear section of a 5th Gen? If no, then you will see what I mean when you try it without a lift.
Not for all cars. I've installed an axle back on a WRX and it could be done with the rear less than a foot in the air.
Originally Posted by tdashmike
I just ordered one from drivewire. Mine is completely broken off.
Yeah, I replaced one on my '95 a few years back. I just used a jack to give me clearance to the muffler. I didn't have to remove my rear wheel or anything. But, it seems my 2000 isn't anything different. This will be my first attempt on this car (hopefully, my last for a while). It should go smoothly, (I hope). But, thanks anyway.
http://forums.maxima.org/showthread.php?t=422651
Not sure if this will help, but here's a thread Irish started when I swapped rear sections with him:
One thing, though....does the reason for being so high have to do with clearing the pipe thru the axle
It also helps to have a towel or some cardboard on the ground so you don't scrape the muffler tips.
Wow! Mine doesn't look as bad as yours. My hole is much smaller but loud enough where I can hear it with my music blasting. It cost you $280.00 installed? Why didn't you just buy the part online and install it yourself? It's very simple. Just a few bolts to loosen and then re-install. Yeah, I seen those Bosal mufflers for about $118.00 shipped. How do they sound, and how long have you had it?
And that was probably 118 USD shipped right? Mine was in CAD. I probably paid more than I should have, in fact, I *should* have welded a sleeve on there, but that's a bigger issue, because i'm eventually going to go aftermarket from the headers back. I needed a decent fix in case I decided to wait a year for the exhaust...and this was the cheapest solution.
Originally Posted by jvienneau
Can't you just replace those flanges with a 1-7/8" coupler?
I could have done that, but that requires effort, and energy...something that money can fix.
That's exactly it. The closer you can get the muffler to point 90 degs downwards, the easier it is to get the pipe out of the "tunnel". We obviously didn't have that kind clearance, so it took some amount of wriggling to find the angle to get it free.
Thanks, Puppetmaster. You're definitely a big help. Yeah, now looking at what I have to work with I can see what I'll be getting into. Did you have to install new rubber hangers? Were they easy to slip thru/off and reinstall?
Gotcha! I went cheap, too, just to get me by for the time being until I find something better in the near future. Just curious, though, how does your Bosal sound compared to the stock muffler? Thanks!
I had the same issue. My buddy works at a shop that does custom exhaust. He just cut the flanges off and welded new ones on. I watched him do it and was not that difficult. He said it was worth doing because the stock pipes are stainless and would last longer than if I replaced with after market.. He knows better .. he is in the business. just my $.02
bbsitum
Sep 11, 2015 04:55 PM
