Progress Rear Anti-Sway Bar
I changed my rear brakes the other day. When I jacked the rear up, I noticed a problem. My Progress rear anti-sway bar is bent!
The center portion has bent up, towards the rear axle. Kind of like the St. Louis Arch (not that bad). It used to be straight with the axle.
What do you think caused this. I was going to remove the bar to see if it would straighten-up and/or flip the bar upside down.
What do you guys think happened?
I think you hit something! I have used the e-brake to slow down. Especially when I'm hauling a$$ down the freeway and notice a CHP merging. So not to show brake lights, I used the e-brake.
Do you know if I can straighten the bar? Or do I need a new one?
I am sure everyone would like to see this. Your car was never jacked up with the bar on from the rear beam causing it to get bent up. Sounds like if you hit something that hard you would remember, and the ebrake causing that sounds impossible. Is there any scratches where it is bent??
Bent Bar
I've never jacked it up from the rear axle. I thought my rear struts maybe are sagging and may be the cause. I really doubt it. I'll take a picture and post.
Merging CHP
Originally Posted by 4DRSpeed
WTF!!????
Originally Posted by K-Town Max98
how much of a difference would a rear sway bar make on a stock suspension setup? (soon to be on gr-2s and progress springs) i want to get a progress RSB before i get my suspension setup.
lowpost99
Oct 26, 2025 06:53 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
