PICS - 300zx 4 piston brake conversion
Old Apr 28, 2006 | 07:33 AM
DeusExMaxima's Avatar
There is good news and bads news. The good news is that I got my brakes on last night. The bad news is that one of the pistons is leaky, prolly due to my fault in rebuilding and so the pedal is mushy. Ill have to take em off and rebuild. But, they look REALLY cool!!! Ill keep you posted on the performance aspect when I fix the leak.
BEFORE:
AFTER:
Old Apr 28, 2006 | 07:35 AM
By the way, the difference in weight is HUGE!!! The stock iron ones have got to weigh near 15 lbs. These weigh about 6. And its soooooo easy to change pads in the 300zx brakes.
SmokedOutMaxi's Avatar
NICE! looks really good.
Old Apr 28, 2006 | 07:57 AM
minsbang's Avatar
nice work~! (god i love your max!!!!!!!!)
Hope you get the problem fixed b4 you get into an accident.
Old Apr 28, 2006 | 08:34 AM
Majestic_MAx05's Avatar
Sweet Work Deus!!! They look sweet on the max!!
Old Apr 28, 2006 | 08:48 AM
RHMax's Avatar
Newbie just Registered
Looks good. What size are the rotors? Those brake pads just slide in and out, don't have to take the calipers off.
Old Apr 28, 2006 | 09:08 AM
I swapped my original brakes back on so i can figure out why the zx brake caliper is leaking. Its only one, so Ill try to rebuild again.
The pads come out REALLY easy on the zx calipers.
The rotors are the stock ones - 12.6" I think?
When I test drove, the brakes are really smooth. Im sure they will be better when I fix the caliper problem.
Old Apr 28, 2006 | 09:19 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
SWEET!, you should paint the letters when you get a chance.
Old Apr 28, 2006 | 09:39 AM
JiuJitsuThug's Avatar
Nice work! I agree with Chernmax - get those letters painted
Old Apr 28, 2006 | 09:41 AM
kamski's Avatar
.org extraordinaire
Deus!!! youare my Maxima Idol!!!
Damn you beat me to it, my wilwoods just left Pheonix on Fedex. And Im expecting delivery by May 5th.
Cant WAIT!!!
Kam
Old Apr 28, 2006 | 09:43 AM
Letters WILL be painted. Wanted to mount the lil beasts first and then touch up paint and thne paint letters. They take a bit of a beating when u mount them.
Old Apr 28, 2006 | 09:44 AM
RHMax's Avatar
Cool, they fit on stock size rotors. I might go this route too.
Old Apr 28, 2006 | 10:04 AM
NismoMax80's Avatar
SuPeRmOd
no jack stands?!?!?!
Old Apr 28, 2006 | 10:29 AM
Apollos2's Avatar
Wow, this is a big difference in weight, that 60lb vs 24lbs. Now help me understand, so the 300zx (not 350z) brake set up is a bigger rotor and caliper/pad set up. Resulting in better stopping and reduced weight.
As far the looks go, are the front rotors still noticably bigger than the back rotors.
And lastly, do drilled and/or slotted rotors give you the same weight reduction?
Dues you are definitely on the cutting edge, with about 4 other org members. Props to the Dues!
Old Apr 28, 2006 | 06:35 PM
The jack stand was under the front . . just kidding . . . Shshshsh . . Yeah I know. I wasnt getting under the car so I figure it was safe.
The brake pads of the 300zx are smaller than the Maxima, but the zx has 4 pistons, thus greater clamping force. Also, the caliper is of a FIXED design rather than sliding, making for more solid braking. I dont expect to get much improvement in terms of braking distance, but I do expect a better feeling brakes and it looks WAAAAAY better than the fugly stock calipers. Its about a $500 conversion, including Hawk Pads, Stainless steel lines and painting the calipers. Its really a nice mod and doesnt cost much more than a regular brake job. ALso, replacing the pads is REEEALLY easy. ANd there are much more option available in terms of pads.
The calipers are 9 lbs or so lighter than the really heavy stock calipers so the total weight savings is about 18 pounds of UNSPRUNG weight, that is weight that goes up and down. That will help the suspension be more responsive and will lighten steering some too.
Now I just have to sort out the caliper rebuild situation. I plan to take them apart and rebuild them again, but Ill be really careful with the seals. I also need to touch up the paint and paint the letters bronze to match the rims.
Old Apr 28, 2006 | 06:37 PM
By the way, rotors are stock!! I do plan to get 2 piece rotors for weight savings (rotational mass). They arent too expensive compared to OEM rotors.
Old Apr 28, 2006 | 08:21 PM
vsamoylov
nice upgrade and do you have the stock calipers? i might buy them from you if you have htem.
Old Apr 28, 2006 | 08:35 PM
Mystery's Avatar
Very nice. Great work.
Old Apr 28, 2006 | 08:38 PM
I have the stock calipers and they are temporarily back on the car until I sort out the zx calipers.
Old Apr 28, 2006 | 08:57 PM
vsamoylov
let me know if you decide to sell them
Old Apr 29, 2006 | 05:27 AM
04WHITESE's Avatar
Rims
Deus just a quick question.
Is there any chance this set up will clear stock 18" wheels.
How much farther do these calipers stick out towards your spokes?
A comparison between stock and the 300ZX dimensionally would be cool.
Please let us know if you get a chance.
Take it easy!
04WHITESE
Old Apr 29, 2006 | 06:07 AM
vsamoylov
Take it easy!
04WHITESE
no way they will clear 6th gen oem 18s. i have tried and they dont work.
Old Apr 29, 2006 | 07:28 AM
Glude's Avatar
Why wouldnt they clear them? Dont the 300zx come with oem 16" wheels? BTW, are you going to be using the lightweight 2 piece rotors from Matt?
Old Apr 29, 2006 | 02:38 PM
Glude, I probably will go with lightweight two piece rotors. Ill try to see if the stock rims will clear the brakes. I think they will.
Old Apr 29, 2006 | 05:37 PM
konak85's Avatar
was your ABS effected at all?
Old Apr 29, 2006 | 06:41 PM
I didnt get to put it through the paces but I couldnt tell anything.
Old Apr 30, 2006 | 01:17 AM
SEXIMA04's Avatar
i have stock calipers for sale... if you are interested. pm me..
Old Apr 30, 2006 | 07:24 AM
04BlackMaxx's Avatar
When you do get to put it through the paces stopping distance testing would be nice to know, maybe it got better? worse?
Old Apr 30, 2006 | 08:38 AM
TAPOUT's Avatar
You will lose
The only thing I didn't like when I did this mod 2 years ago, is the selection of rims that clear them suck.
Old Apr 30, 2006 | 10:27 AM
My rims clear them by far. They are A-Tech 18x8. Also, if you do this mod, you would want rims that are of an open design, so that they can be seen, I would think.
Old Apr 30, 2006 | 10:35 AM
Here are some more pics:
Here is a pic showing the Blehmco adaptor bracket:
Old Apr 30, 2006 | 10:45 AM
Pic showing how easy it would be to replace pads. You pop off that wire retainer, pull out the two pins and unclip that top metal spring thing and out they come:
One more pic:
Old Apr 30, 2006 | 11:05 PM
Blue Batmobile's Avatar
Damn that looks sweet! I'm going with Red Calipers on my Viper as well .
Bat™
Old Apr 30, 2006 | 11:15 PM
RHMax's Avatar
Deus, how is the bias with the stock rear?
Old May 1, 2006 | 06:08 PM
I believe the bias will be fine. I still havent put it through its paces yet. I plan on putting the calipers back on this weekend after i rebuild again to see why one piston is leaking
Old May 2, 2006 | 12:22 PM
JoesRedMax's Avatar
Hey Deus, that looks awesome. I'm in the process of purchasing the same brakes, could you hook me up with the adapters?
Old May 2, 2006 | 12:46 PM
kamski's Avatar
.org extraordinaire
http://www.blehmco.com/
go here.
Kam
Old May 2, 2006 | 05:53 PM
BadBlackMaxSL's Avatar
Deus, The looks of the bigger calipers really makes it look way more aggressive. Just one question/comment. What color did you paint those? It looks like a shade of lipstick a young girl would wear. Is it the brightness of the flash causing that? If they were a darker, fire engine red they would look better to me. Well, now that I gave you a backhanded compliment I should probably go hide.
Keep up the good work. I am always interested to see what you do next.
Old May 2, 2006 | 11:37 PM
The caliper paint I used is Duplicolor Red. Its like a Porsche Guards red, a fire engine red. The camera has a hard time showing the actual color, but it is really nice in real life. The flash probably does distort the color somewhat. Ill remount the brakes and take day time pics.
Old May 3, 2006 | 11:19 PM
I am re rebuilding the calipers. I took them totally apart this time and used lube to get pistons in. MUCH better. However, two seals were damaged. So Ill order a new kit and finish re rebuilding and mount the brakes back on and try it out.
