Best swaybar endlinks??
im assuming this is for an adco? I was wondering the same thing, cause i found an adco, but the brackets and bushings were missing...never found out where you could get replacements...
would be nice to know...
The front end stock sway bar end links are ball joints. There is no play in them.
The only way to make the the front sway tighter is to use tighter bushings on the ends of the links & the bushing that hold the bar.
Therefore, the best sway bar end links are OEM.
So energy suspension does not make bushings for the enlinks just the sway bar bushings 20mm I think. I guess oem will have to do and I will put the energy suspension on the bar itself. For the second post not the rear sway bar and you can get the hardware brand new for $50 for the bar.
Suspension Restoration parts: http://www.suspension.com/nissancars.htm
sells the bushings that go on the sway bar endlinks, you need four of them. part #4803-G.
Courtesy nissan also sells them for cheap...www.courtesynissan.com
And they are only $00.86 each and you need four, two for each side.
I'm in the process of assembling parts to rebuild my front end (along with a drop). I went to Car Quest. They use MOOG products which have had a good reputation.
CCH K9824-Sway Bar End Link Kit= $37.82
The guy was kind enuff to give me a discount because I bought everything except the inner tie-rods (everything all together would have been around $310.00(!))
Still, everything else came to $198.52
i got all oem endlinks and stuff from infiniti for under $49 for both sides, OEms is the way to go for the end links. Foe the Lower control arm i puchased ES LCA bushings and sway bar bushings
^^^Jsutter where do you get those, saw a pair a couple months ago here for sale just like that but can't find them again. I thought you had to make these yourself......any help is appreciated.
I think you do have to put them together. I havnt seen someone sell them specifically for the Max. With some Googling Im sure you can find the stuff needed. Check other Nissans to see whats out there already.
kingw323
20
Oct 21, 2015 08:36 AM
maxdis1
Mar 17, 2003 06:59 AM
Kevin
Jun 28, 2002 08:09 AM
