Sponsored by:
Sponsored by: CARiD
where does this coolant sensor go on the 3.5?
Old May 1, 2006 | 04:25 PM
chris'smax's Avatar
What do you guys do about the coolant temp sensor. On my de-k there was a bung that the sensor screws into and on the 3.5 i can't seem to locate it. Is there one or did you guys just drill and tap a fitting?
Old May 1, 2006 | 04:28 PM
Nismo3112's Avatar
Custom User Title
You have to reuse your 3.0 coolant log.. The one which connects to both heads on the side.
Old May 1, 2006 | 04:43 PM
chris'smax's Avatar
fugging ****. Was that in any of the other threads becuase if so i missed that one! Is that the only reason for using that coolant log or is there something else that requires you to use the 3.0 one.
Old May 1, 2006 | 04:51 PM
Jime's Avatar
Thats the only reason I know of. I know I read it in there somewhere.
Old May 1, 2006 | 04:53 PM
mforrest100's Avatar
Don't remember seeing that at all in all the threads I've read on the 3.5 swap. Looks like I need to start all over
Old May 1, 2006 | 04:58 PM
Nismo3112's Avatar
Custom User Title
I first noticed it when I looked at the 3.5 water log and saw only 1 sensor bung. I also don't think this is in any of the threads!
Old May 1, 2006 | 05:04 PM
nismology's Avatar
http://forums.maxima.org/showpost.ph...8&postcount=55
http://forums.maxima.org/showpost.ph...9&postcount=57
Taken from the sticky...
Old May 1, 2006 | 05:11 PM
Nismo3112's Avatar
Custom User Title
D'oh
you =
Old May 1, 2006 | 05:54 PM
diymaximakid's Avatar
you dont have to use it.what you do is mount the sensor by the coolant hardline(is this what its called)?and it will read accuratly within a few degree.if you want i'll take a pic
Old May 1, 2006 | 06:05 PM
chris'smax's Avatar
yea if you don't mind that would be awesome. Doing that sounds much easier than switching out the coolant tube.
Old May 1, 2006 | 08:51 PM
nismology's Avatar
Sounds kinda ghetto to me.
Old May 1, 2006 | 08:55 PM
Nismo3112's Avatar
Custom User Title
It's not that difficult to swap out the coolant log...
Old May 1, 2006 | 10:11 PM
japmaxSE's Avatar
Go Get a Life!
What he said it's very simple...
Old May 1, 2006 | 10:16 PM
nismology's Avatar
I don't get how swapping out the coolant tube seems like a big mission considering that installing the 3.0 timing covers and chains/sprockets is 10 x's more labor-intensive.
Old May 2, 2006 | 12:49 AM
yeah tru but unless you looking for it you could never tell the difference.
Old May 2, 2006 | 03:55 AM
chris'smax's Avatar
well as much time that this has taken i just get aggravated when i have to go back and re-do things i have already done.
Old May 2, 2006 | 05:58 AM
Fred Allen Burge's Avatar
Tell me about it. I'm on my 3rd set of motor mounts, 5th intake manifold (between two different motors), second ECU, second wiring harness, second coolant log, second radiator, the list goes on and on.
allen
Fbana41
Aug 29, 2016 12:18 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
msellas
Sep 23, 2015 09:16 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
bumpypickle
Sep 20, 2015 08:22 AM
