Turning Crank Pulley ?? Picture !!
Old May 1, 2006 | 08:41 PM
matty's Avatar
Well I have my 2000 motor completely stripped down to the block. 8500 miles on it.
Im starting to prep it so today I put in some new oil and some new gapped plugs. I plan on putting this in, in about 2 to 3 weeks once this semester is done and over with but right now Im just waiting for parts.
I decided to turn the crank pulley and just turn the engine a bit. It it normal when I turn the motor that it gets really hard to turn, then eases up, then really hard to turn, then lossens up ?? Im using a 3/8 rachet with a 19mm head it on. Not a big bar, just a little rachet. What I mean by hard is that there is alot of resistance on the Rachet, then it gives way and turnes the rest of the way around...then tight, then loose again and so on and so on.
I just wanna know if its normal
Picture of what were dealing with:
Old May 1, 2006 | 09:14 PM
eng92's Avatar
That is normal for an engine with the plugs in it.
Old May 1, 2006 | 09:34 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
its the pressure from the valve springs i think that itl do it without the plugs..
Old May 1, 2006 | 09:35 PM
1FSTMAX's Avatar
compression stroke ownz..
Old May 1, 2006 | 09:56 PM
motorheadwannab's Avatar
lol ya dude just pull your plugs out and it will be easy
Old May 2, 2006 | 12:17 AM
GodFather's Avatar
Made in Taiwan
yeah, all that pressure builds in the intake stroke of your 4 stroke cycle. it's hard to overcome that inertia when you first wanna turn it. then it'll get easy as you go because the counterweights are easing it up as you go.
Old May 2, 2006 | 01:04 AM
90stanza's Avatar
Its just the compression stroke doing its job. If you listen close enough you can hear the compressed air seeping out when the exhaust valve opens up.
Old May 2, 2006 | 07:39 AM
matty's Avatar
Is it also normal to hear a bit of noise coming from the timing chain ?? Figure cause there is no Oil pressure thats probably normal
-matt
Old May 2, 2006 | 04:01 PM
RA030726's Avatar
I'm nutty for Nissans
Yea there is some slack in it until the tensioners get pressure.
mvm062
Nov 30, 2020 09:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
doctorpullit
Sep 10, 2015 06:33 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
