help I need a Radio Schematic (wiring diagram)
I'm putting a line to RCA converter on my factory radio(for my subs) but I need to know which wires are front, rear, left, right, positive, negative, antenna remote, etc. Any suggestions where I can find this info? I specifically need to know which wires match or go together and which are negative. thanks in advance.
since no one responded...
Generally a pair of same colored wires runs to each speaker (4 different colors for 4 speakers). One wire will have a black stripe on it - that is the negative wire, the other (duh) is positive. My factory Bose/Clarion had the wireing schematic printed on a sticker on the botom of the HU.
Mike
Mike
WHatever u do dont ground out the positive lead of the antenna
Originally posted by Botos
http://www.installdr.com/InstallDocs/Nissan/Maxima.html
here goes:
make sure you install the high/low converter behind the radio, NEVER INSTALL AT THE SPEAKER!
FACTORY HARNESS WIRES
BATTERY: pink/blue
ACCESSORY: blue/black
GROUND: chassis
ILLUMINATION: red/blue
DIMMER: red/orange
POWER ANT: black/red
SPEAKERS
FRONT LEFT: (+) blue/white
(-) blue/yellow
FRONT RIGHT: (+) brown
(-) brown/white
REAR LEFT: (+) red
(-) green
REAR RIGHT: (+) blue
(-) pink
hope this helps you bro!
"certified car-audio installer"
Anthony
BATTERY: pink/blue
GROUND: chassis
DIMMER: red/orange
SPEAKERS
(-) blue/yellow
(-) brown/white
REAR LEFT: (+) red
(-) green
(-) pink
Anthony
I appreciate the help, I did figure the wires out. I used the aftermarket harness. I plugged the harness and followed the color coded wires to the factory wires and that's how I figured them out. i.e. I followed the green wires till I ran into the factory wire revealing the speaker wire. Like I said thanks man.
I already had a harness on my aftermarket radio but went back to the factory stuff so it was easy to figure out my leads.
