Passenger Window switch LED replacement
Has anyone replaced the passenger window switch light with an LED? I've got the driver's side and passenger door lock switches finished, but am not sure how to put in an LED for the window switch. Any input would be appreciated. (Pictures would be nice too)
You have to pry open the switch to access to the LED that is already in there. Once you open it, a "see-saw" like piece of metal and some tiny metal ***** will fall out. Make sure you don't lose these. This is what makes the switch open and close the window...up and down. Anyway, once you have the switch open, remove the ugly green LED and solder a new one in there of your choice. Reverse the procedure for install.
Originally Posted by BigL0U
How bout that how-to about the positive and negative ends on the LEDs ... in any case the full write up with those references...
If anyone's looking for a write up, here's the one that i ended up finding and using:
http://www.cardomain.com/ride/305093/7
Originally Posted by KabirUTA13
normally on the led... the longer end of the led is the positive...
a quick and easy way to tell the positive and negative is just take out your battery out of your remote for your car and connect it to the led and if one side doesnt work flip it over and then when that works just look on the battery to see which side is positive and then remember which one it is long or short prong..................
vingodine
45
May 21, 2016 12:46 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
kjm900r
Aug 5, 2015 07:14 AM
