How to disable day time running lights?
I recently installed a low beam only HID kit into my 95 Maxima and am having problems since the right light keeps flickering on (at times stays on) while in the off position. Since I baught it through Ebay, the seller told me to disable the day time lights since this may be the problem.
I am not sure how to disable them?
ya I don't recall any maximas having day time lights... the seller was obviously bsing u, maybe u just installed or wired the HID wrong and is causing a short of some kind to ur right headlight unit making it flicker...
Remove the fuse. its in that fuse panel above the hood release thingy.
I also lost my DRL's when i went HID. Rewired my fogs to go on with all the other accessories(theres a writeup in the stickies).
Had to do this for my Bi-Xenon retrofit......
There are two connections going into the
DRL module (hiding near the windshield washer nozzle).
Pull one of the two wires and DRL will disable. For some reason
on my car if I took out the DRL module completely the passenger
side headlight stopped working.
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
