can cheap gas mess-up your engine?
Old Jun 6, 2006 | 06:50 PM
ktranne's Avatar
NOOB
last week I let my bro-in-law borrowed the car for 2 days. (his work)
the car rattle on the engine when I step on gas (ex: going 40, want to pass a car, step on gas, engine rattles at first but none when it reaches higher rpm.)
I know he put on cheap gas 'cause dat's him.
anyway, I had a code about 3 months ago for 5th engine misfire, changed updated brand new coils and spark plugs.
Thanks guys.
Old Jun 6, 2006 | 06:53 PM
ktranne's Avatar
NOOB
also, I always use premium.
I think my bro-in-law put on 87 octane gas.
I have been putting on 3 tanks of 93 octane and it seems the rattles more quiet, but it stills there.
Old Jun 6, 2006 | 07:11 PM
s70's Avatar
s70
maxima's are made to be able to run on lower octane, but it is recommended to run higher. Unless you have tuning of some sort, i cant really see that being the problem
Old Jun 6, 2006 | 07:21 PM
96pearlmax's Avatar
always run premium or your gonna get a little octane ping.
Old Jun 6, 2006 | 07:27 PM
Killercam2's Avatar
I alway use premium nothing else
Old Jun 6, 2006 | 07:37 PM
ktranne's Avatar
NOOB
yea, I've always run on premium. Especially over here we have 93 octane.
so what's with the rattles on the engine? my friend told me I need a tune up. But I just replaced coils, spark plus...........
or is it the result of my 2 months old Berk intake? hehehe.
Old Jun 6, 2006 | 08:09 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
nothing wrong with using low octane but you will hear the knocking(ping)....
Old Jun 6, 2006 | 08:35 PM
ktranne's Avatar
NOOB
ohh, thanks guys.
No pings but just rattles come from the engine whenver I step on the gas a little more than normal.
Old Jun 6, 2006 | 10:30 PM
MaxBoost925's Avatar
Drug Money
detonation is irreversable FYI
Old Jun 7, 2006 | 06:15 AM
ManUtd18's Avatar
can you run with mid grade gas? or is premium the best to get? i thought you would only use premium if you got a chip.
Old Jun 7, 2006 | 06:51 AM
nissanluva's Avatar
When gas prices started getting nasty, I started using regular gas regularly. At first I couldn't detect any diff. - no knocking, no pinging, maybe a little power difference. After a while, with everybody telling me that I should be hearing something, I started noticing a little rattle from the engine when it first start and when I first step on gas. Now, I alternate tanks between medium and premium. Also, I think I get slightly better gas mileage with premium. In my opinion, Nissan's got a lot of nerve requiring (or recommending) premium, when Accords, Camrys, and every other mid-size, mid-level sedan only needs regular (and they get way better gas mileage, too) - geez, a 300HP Mustang only needs regular!
Old Jun 7, 2006 | 06:58 AM
weshaley20's Avatar
Yep, I got the same rattling sound upon acceleration. I've always used premium, and still started getting the knocking sound. I've been using mid-grade lately since the knocking is there anyway. The dealer said it could be some kind of spark knock, timing issue, or sensor problem as well. I guess the rattling isn't that detrimental, but more annoying.
Old Jun 7, 2006 | 07:32 AM
† ErV †
89 is the limit for mine and even then i can feel it running poorly. that said i've probably ran about 60 gallons of 89 through it and that's when gas was 3.30+
Old Jun 7, 2006 | 01:08 PM
NickR's Avatar
yeah, it may be a spark gap issue too. i agree w/ recommending premium. I had to use it in my 00 Jetta and 04 TSX. My wife hates that I always use it but it's not that big of a deal over the course of a year. I think it costs about $300 more per year to use 91/93.
With prices so high, I typically will use 89 for one or two tanks outta five.
Old Jun 7, 2006 | 02:25 PM
frankd121's Avatar
using 87 shouldn't harm the car...our cars have knock sensors which will retard timing when engine knock is detected. however, you will notice a decrease in gas mileage and power. the decrease in gas mileage, in my opinion, is not worth saving a few cents for cheaper gas.
Old Jun 7, 2006 | 05:42 PM
spdfreak's Avatar
Theres not that much of a price differance between 89 & 93 octane gas!
The reason I took the 2 seconds do do these calculations is because I want to show everybody how filling up on 89 or 93 octane doesn't break the pocket.
I was kind of board so heres my calculations:
If 87 costs $3.19, 89 costs $3.29 and 93 costs $3.39 Per Galon (Prices I've seen in NY)
If you fill up 12 galons at a time then it costs $38.28 for 87 octane, $39.48 for 89 octane and $40 for 93 octane.
So for the record its a meer $1.72 differance between the top and bottom octane levels...And thats not going to break most peoples pockets!
"I hope I stand correct, if I don't I'll be willing to edit the post."
Old Jun 8, 2006 | 06:43 AM
03MajesticMax's Avatar
Shift_MajesticFemale
Does it make a difference if you get Premium From Amoco/Exxon (Name brands) or if you get it from mom and pop stations?? I have always been to afraid to fill up at those non namebrand gas stations... shoud i be?
Old Jun 10, 2006 | 11:46 AM
ktranne's Avatar
NOOB
I had a 92 SE for 10 yrs. with mom and pop stations w/89 octane. Never had any problem except for a fuel pump.
I started to put premium on my '00 when I bought it.
Old Jun 11, 2006 | 08:10 AM
SilverGLE's Avatar
I'm watching you, boy...
FYI: The third generation Camry V6's (92-96) required 91. Personally, I don't put in less than premium (which is 93 around here). If gas gets insanely expensive, I may drop to plus. My dad (being the cheap person and slow driver that he is) never puts anything above regular in his I35....
Old Jun 11, 2006 | 11:24 AM
Bobo's Avatar
My sister has a 94 Camry V6 and the manual calls for 87 octane.
Old Jun 11, 2006 | 11:14 PM
magninpi's Avatar
cheap gas, no ping here ...
Hi,
My 01 has had mass airflow replaced, gaskets, 02 sensors, and 2 coils under warranty thankfully.
Until the above was performed, the "check engine light" was on and it pinged like a banshee.
I always use name-brand cheap gas (87) with no ping at all during any circumstances. Maybe it depends on elevation a bit?
Old Jun 11, 2006 | 11:40 PM
SilverGLE's Avatar
My bad...... Must be thinking about something else...
Old Jun 12, 2006 | 12:05 AM
cpuguy06's Avatar
I always use 91+ up here in north dakota, all we have is 91. This winter when it was really cold I definately noticed a difference between 91 at BP(Amaco) and 91 at cenex. The car ran a lot smoother and starter a lot more easily. People always give me crap for puttin in BP(Amaco) premium, but I figure the manual says use premium for maximum performance, and it only costs like 2 - 3 bucks more a tank, so I figure its worth the hassle. Instead of wondering, I just put 91 in and no problems..and if your comparing to 89(w/ethanol) forget it 91 beats 89 w/ethanol outta the water, I have heard and seen nothing but bad things come about from using ethanol.
Old Jun 12, 2006 | 05:23 AM
ctrent86's Avatar
Ethanol cant be run safely in maximas I thought unless you do some fuel line change out and some conversion pieces because over time (not much time by the way) will eat away at the fuel system componets. This is due to the fact that the ethanol we use (corn instead of sugar like the rest of the world which is way cheaper to make btw) is very corrosive. Someone correct me if I am wrong in this. Also in the way of name brands it is stated that Chevron has been stated to be the best gas. I have heard for a friend of a friend in the gas business that Ammaco is the best in teh way of less detergents and what not.
Old Jun 12, 2006 | 09:28 AM
1MaXXfan's Avatar
Opinons, opinons
BP Amoco,
Unofficial study of mine over the years with a friend has been that they always ran our cars better (93) than any other brand we've used. He loves Fords and they too run better on Amoco, so we did some comparisons on MPG etc. This was several years ago, back when we were in college.
It gives me better power, acceleration but not necessarily the best MPG. It'll give me 22-23 mixed highway local. NY area traffic conditions. So it can drop to around 19 MPG also.
Mobil on the other hand has for some reason given me the best MPG when going long range, i.e. from NY to Boston. Got almost 27 MPG. Keep in mind I've kept my Max stock.
Speaking of this, when I put in a CAI, will this improve MPG, stay the same or kill it?
Old Jun 12, 2006 | 09:44 PM
ktranne's Avatar
NOOB
I have berk intake w/apexi filter and it actually improved MPG.
Old Jun 12, 2006 | 10:24 PM
whitegold's Avatar
In NY we have 10% Ethanol in our gas.. my dad used to own a gas station years ago and they always said Amaco had the best gas.
Old Jun 14, 2006 | 10:12 AM
96pearlmax's Avatar
agree totally. Amoco has the best fuel around
Originally Posted by 1MaXXfan
BP Amoco,
Old Jun 14, 2006 | 11:10 AM
jphoto's Avatar
My understanding is, if your engine is working 100% properly, putting in normal fuel will only affect your performance (by 10-15 HP or so?). I use 87 most of the time, and the car is generally commuting to work and back so it's not like I'm missing the horses.
Old Jun 14, 2006 | 12:14 PM
ktranne's Avatar
NOOB
only if your car's running 100%. 93 help with my rattle on the engine, that's the way I see. Maybe I'm wrong but it make the rattles not as loud as b4.
Old Jun 15, 2006 | 07:28 AM
rmd0311's Avatar
To add to the Nissan only thing... My wife's Toyota Sienna requires 91 or above. You can use 87 or 89 but you feel the difference. This is the same engine that is on the Camry.
The new camry v6 also requires the higher octane.
The 2 dollar per tank difference I think is not enough to put your vehicle at rish of pinging, knocking, retarding timing and loss of power.
93 all the way...
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
slowlifer
Sep 8, 2015 05:53 AM
dcam0326
Sep 7, 2015 07:26 AM
TheMafia
Sep 4, 2015 08:26 AM
