95 Maxima odometer/speedo on the way help!
Old Jun 7, 2006 | 11:12 PM
flynlr's Avatar
just ordered a new speedo /odometer for my 95 max and as I have removed the cluster numerous times to check for cold solder joints on the cluster i can get to the speedo very easily.
I just read the threadhttp://forums.maxima.org/showpost.ph...46&postcount=2
on how to remove and install the gauge needle but does this rule apply when changing out the whole gauge?>I mean I am sure it comes without the needle preinstalled. so how would i be sure its calibrated? when i put the old needle on the new guage?
Old Jun 8, 2006 | 10:27 PM
flynlr's Avatar
no one here has changed out the speedo?
Old Jun 8, 2006 | 11:37 PM
whitegold's Avatar
My odo is acting up.. I thought changing these things were a PITA so no1 ever did it?
Old Jun 9, 2006 | 12:09 PM
flynlr's Avatar
bleh im retarted.... total install time was 20 mins and the new one had the needle installed,
so now what to do with a working speedo at 35k miles but has a bad odometer......
ebay?
Old Jun 9, 2006 | 12:32 PM
Toolrocks's Avatar
The speedometer and odometer get their signals from the same source. They should both work. My odometer quit working a long time ago but the speedo is still good.
Old Jun 9, 2006 | 03:01 PM
hasei's Avatar
日産
ebay?
How about selling your old gauge here because those who want to recycle parts of a speed gauge might still want to buy your speedo with non-functioning odo.
Old Jun 9, 2006 | 10:14 PM
flynlr's Avatar
sound like a plan . rather sell it here then ebay.
do i need to post in the FS/FT sub forum?
Old Jun 18, 2006 | 10:21 AM
max ride 41's Avatar
got an entire cluster for my 95 from my buddy. 165.00 with close to the same mileage 141,491, i have 149,614 so i hear its easier to replace the whole thing. i'm gonna do it myself, any tips?? thanks in adxance>> big b
Old Jun 18, 2006 | 04:06 PM
Toolrocks's Avatar
The install is very easy but as long as you've got everything out, I'd go ahead and replace all the cluster's bulbs. It would suk to have a bulb go out soon after you've replaced the whole thing.
Old Jun 18, 2006 | 11:31 PM
flynlr's Avatar
its funny the 7 or 8 times ive had my cluster out i never even thought of changing the bulbs. .on the other hand I can get it out in 5 mins now.. practice yah know
Old Jun 20, 2006 | 04:25 PM
Toolrocks's Avatar
I hear ya on the practice. I've had mine out several times too. Since you're experienced I wouldn't worry about it - you know, bulbs only blow out after they've been replaced ha!
Old Jun 20, 2006 | 07:56 PM
so, any stickys in forums to remove dash peice?? you say its easy, but i am not that secure with screwin around with the wiring. how many screws, where to start??? thanks again big b.
Old Jun 21, 2006 | 03:03 AM
aznxenon's Avatar
lol I need a cluster for just the rpm tach, speedo and odo works fine on mine
Old Jun 21, 2006 | 08:45 AM
maxprivate's Avatar
Black Lion
speedo
this is very simple to do. when i drdered my speedo head from courtesy nissan they calibrated it for me . i just gave them my current mileage. I received my ready to install , just remove the cluster and behind the speedo rremove the four screws holding it in . Remove the old speedo and intsall the new one . put it all back together and your done. Thats how simple it was for me. i hope this helps.
Old Jun 21, 2006 | 09:15 AM
DBear's Avatar
Well, not quite that simple. You have to take out 3 or 4 trim pieces first. They're only held in by a few screws, but there are a couple of moments where you have to hold your breath and pull to get the clips out. And it took me a while to figure out there were 2 more screws holding the 2 piece steering column collar in place. I think the manual said there were only 4, and I believed them. But once you've done it, it really should be about a 10 minute job.
Old Jun 24, 2006 | 03:48 PM
ya ya , trim peices are the biggest pain in the ***!!! i broke the main trim peice on left side pullin it out and was pissed, but i got it to go back in and you can;t even tell its busted, luckily.........
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
