Air Conditioning Question - Need Your Help
Old Jun 9, 2006 | 06:23 AM
shobuddy's Avatar
Quick, simple question on an 03 Max:
When using the AC, is the "recycle air" button supposed to work with the foot, foot/defrost and defrost outlets. The manual says it automatically turns off when using it on heat but says nothing about it automatically turning off when using it with the AC.
Also, if the recycle air button automatically shuts off for foot, foot/defrost and the defrost outlets when heating, are you able to manually turn it back on?
Any input would be greatly appreicated. Thank you.
Old Jun 9, 2006 | 07:42 AM
nicks79's Avatar
i know it automatically shuts off on any defrost settings.. otherwise you;ll fog up..
Old Jun 9, 2006 | 07:43 AM
UGAd13's Avatar
Originally Posted by shobuddy
When using the AC, is the "recirculation air" button supposed to work with the foot, foot/defrost and defrost outlets.
Yes.
Don't know.
Old Jun 9, 2006 | 07:51 AM
shobuddy's Avatar
Yes.
Something must be wrong w/mine then b'cuz the recycle air button won't work w/the foot, foot/defrost and defrost outlets whether heating or using AC. It was working before but I had a guy do some work on my stereo two days ago where he had to remove the entire center panel. It hasn't worked since then. Any ideas on what the problem could be?
Old Jun 9, 2006 | 04:39 PM
MIXXMAX's Avatar
If your center panel was removed, then yes I would check all the wiring behind the A/C unit. It is more than likely a wire(s) may have come loose or stretched.
Old Jun 9, 2006 | 07:30 PM
shobuddy's Avatar
The guy came back and checked all the wires, everything was plugged in fine. Basically the AC is mimicing the heat settings as far as not beign able to recycle the air for foot, foot/defrost and defrost. Very weird.
Old Jun 12, 2006 | 10:07 AM
shobuddy's Avatar
Anyone know why the recycle button wouldn't work w/the foot, foot/defrost and defrost outlets when using the AC? Thank you
Old Jun 29, 2006 | 06:23 PM
shobuddy's Avatar
edited - blank
Old Jun 29, 2006 | 06:33 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I don't think that's it. I recall someone having a similar problem a few weeks ago. Now I'M having the same problem.
Old Jun 29, 2006 | 06:35 PM
shobuddy's Avatar
Do you know what caused your problem and did it go away by itself and come back again?
Old Jun 29, 2006 | 06:44 PM
No, no, and by default, no.
Old Jun 30, 2006 | 04:58 AM
shobuddy's Avatar
Aaah I misread your post. Thought you said you were having the same problems a few weeks ago and now you're having it again. Thanks for clarifying.
rbuswell
Nov 17, 2016 04:54 AM
95Maxi
Aug 29, 2015 09:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 5, 2015 09:02 AM
