glue around transmission fill plug
use a short extension and a breaker bar to pop it loose.
a lot of times you will get seepage around the fill plug if you don't put a small bit of RTV on it. usually all I do is put a thin layer of RTV on the threads when I put it back in and I don't have any problems.
Also note you don't need to crank that thing in there like that. (I've even seen tranny cases crack because of people putting them in too tight.) all you need to do is get it snug and use the RTV to keep the thing from seeping.
HYELLL NO, don't HIT it with anything, you'll most likely miss and smack yourself in the head with it.
go to the hardware store and buy yourself an iron pipe approx 12 inches long
eg gas line pipe 1 inch
slide this over your ratchet handle, this will give you plenty of leverage.
good luck and be safe ...
Mar 12, 2020 12:06 AM
