Ground controls and spring isolators (4th gen)?
I have ground controls on my my 95 and I was getting noise from the rears. So I looked into it last night. My problem is coming from the upper spring perch pushing thru the isolator (thick rubber peice) and then I get a rubber squeeking noise. Does anyone have experience with this? I actually have been very happy with the ground controls so far as far as drop/handeling/noise and would like to get this figured out. The other twist that I have thrown into this is that I am using Ben's rear long travel mounts so the isolator is free to slide around since there is not a groove for it to sit in. I am thinking I need to make custom isolators. Does anyone know where I can buy thick enough rubber to make isolators? Or has anyone sucessfully corrected this problem. Thanks for any suggestions.
Originally Posted by Cutler
remove the rear mounts and see what happens. If the noise goes away then you have found your issue....
Originally Posted by Matt93SE
have the long travel mounts machined with grooves for the perch in it.
sounds easy enough to me.
Then you either need to have the right parts machined or take them off completely. round plug, square hole.
Can you post a pic? I have bens mounts, CG's, and while they are not on the car they seem like I put them together well. I dont think there will be any noises. I dont remember the exact order of parts, but there is a bunch of rubber bushings all over between the metals.
Finkle
Sep 27, 2015 09:53 PM
