Windshield Wipers Don't Work
Old Jun 16, 2006 | 11:09 AM
il99max's Avatar
Windshield wipers don't work and it's not the fuses. Fuses are okay. Could it be I need a new wiper motor?
Also, the A/C and heat do not work as well. No air blows out and I don't hear the compressor kicking on. For the A/C, could the freon be empty?
Thanks.
Old Jun 16, 2006 | 12:38 PM
DBear's Avatar
For the air problem, does the blower motor work on high and no other setting? If so, it's the blower motor resistor. About a $40 part, and ridiculously easy to replace.
Old Jun 17, 2006 | 04:33 AM
200kMax's Avatar
maybe u have a bad relay and not a bad fuse?
check the wiper control by the passenger relays.
btw: it wouldnt be the motor resistor b/c even at speed 1, 2, 3, the a/c compressor would still kick in. i had the same issue before i changed my resistor.
it may actually be a leak or the compressor is shot.
Old Jun 17, 2006 | 05:00 AM
vvslavavv's Avatar
For the wiper blades, do you hear the motor running? If you do, you probably screwed up the linkage!
Old Jun 19, 2006 | 08:37 AM
il99max's Avatar
A/C compressor does not kick in on any setting (digital climate control). I can turn on the A/C or the heat, put the fan on settings 1, 2, 3 or 4 but no air blows out of the vents and I don't hear anything kicking on.
For the windshield wipers, no engine running.
Old Jun 19, 2006 | 08:43 AM
vvslavavv's Avatar
When you say no engine running, do you mean your car's engine???
I'm talking about the wiper motor.
Old Jun 19, 2006 | 10:04 AM
il99max's Avatar
No. I'm talking about the wiper motor. I don't hear anything from the wiper motor when I turn the wipers on.
Old Jun 19, 2006 | 03:43 PM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
Check fuse/relay, connection to motor.
vingodine
45
May 21, 2016 12:46 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
DZN13
Aug 24, 2015 11:00 AM
jchronis2552
Aug 13, 2015 07:48 AM
kenc15
Aug 5, 2015 08:29 AM
