How long can a Maxima sit without being used?
Im gonna go on vacation for a couple of months and the MAX will have to stay behind, i'm leaving the keys with someone I can trust. Do I have to tell them to start it up every now and then (it's summer and average temp is 65-70 f ) is it Ok if I leave it with a full tank or an empty tank? The MAX will go unused for almost 2 months, what should I get done to make sure it's driveable once I get back...?
I would fill the tank. Less chance of condensation. Also, change the oil now and after you get back. It's not imperative, but the acids that build up in motor oil can be caustic to an engine. It doesn't seem like it will be sitting that long so I wouldn't get too extreme.
Tell the person to drive it from time to time. And tell them to run the AC when they do. It will help keep the seals intact. Keep the gas tank full as others have said to prevent condensation. Don't leave it in direct sunlight. Also when they drive it, it's best to drive for a long time to get everything hot to cook all the impurities out of the oil that will build up.
Originally Posted by JHowell37
...tell them to run the AC when they do. It will help keep the seals intact. Also when they drive it, it's best to drive for a long time to get everything hot to cook all the impurities out of the oil that will build up.
Two months is a little bit too long to idle. If I were you, I would ask the trusted one to drive the Max at least once a week.
I used to left my Max untouched about two and half weeks (under porch, in open air, California winter). After I came back, my Max started and ran as usual.
1) Change the oil first.
2) Put in fuel stabilizer before your final fillup. I don't think the amount in the tank matters much, as long as you follow the directions, and run the car for a while so that the fuel stab. gets spread thru the whole fuel system.
3) The stuff about tires shouldn't matter for 2 months. Just be sure to check the tire pressure before the first drive.
Originally Posted by nismology
I agree with everything but number 3. Flat-spotting can be in issue after just a week of sitting depending on the tire.
My F1s would feel slightly flatspotted for the first 1/4 mile after a month of sitting, but that's it.
kjlouis
Nov 24, 2018 06:09 AM
ramtin325i
Aug 8, 2015 05:13 PM
