96 I30, no speedo no odometer
I picked up this I30 but the odometer and speedometer don't work.
Trans shifts fine as near as I can tell. No codes came up on my scanner.
well, I did come up with a bad o2 sensor code
If you don't have a VSS code, chances are, you may have to replace your speedometer. It's somewhat common especially among 4th Gen. Maximas. Sometimes re-tighten all screws that hold speedometer to the cluster will fix this issue, even if the screws don't look loosen, you can try it before replacing the speedometer. Replacing a VSS to see what happens is another option, because obviously it's cheaper than replacing a speedometer. In my experience this issue with AT transmission sometimes coninsides with flashing O/D lights indicating a TCM error.
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
