car cut off on the highway
Old Jun 26, 2006 | 04:22 AM
mb1's Avatar
mb1
Getting on the highway car began stuttering. Jerking around. As I was pulling off on an exit, it cut off and the CEL came on. I turned it on and managed to drive it to a steet, pulled the code and got 0505(nothing). reset ecu, let it sit 5 mins and drove off. after getting back on the highway same thing. i pulled on the side, let it sit, athen drove it to my exit. let it sit for about 10 mins in a parking sot again because it cut off. Then drove it to the deck, this time without a problem. The cutting off happened as soon as i would get on a highway. Roomate thinks its the fuel pump. what do you guys think?
Old Jun 26, 2006 | 04:26 AM
njmaxseltd's Avatar
Pull the codes.
Old Jun 26, 2006 | 04:44 AM
mb1's Avatar
mb1
Originally Posted by njmaxseltd
Pull the codes.
0505 nothing wrong
as stated above
Old Jun 26, 2006 | 04:55 AM
Caracicatriz's Avatar
What was that?
Check spark plugs, fuel filter. I had the same problem only at lower speeds. Could be a misfire in one of the cylinders.
Old Jun 26, 2006 | 04:57 AM
streetzlegend's Avatar
If it was mistfire, wouldnt that show on the codes?
Old Jun 26, 2006 | 05:02 AM
mb1's Avatar
mb1
sparkplugs and fuel filter were changed about 30k miles ago. 300zx filter was put in so i doubt its cloged.
Old Jun 26, 2006 | 05:27 AM
like you were told, perhaps its the fuel pump, since on the highway you have to apply more gas and more constant.
Old Jun 26, 2006 | 05:29 AM
mb1's Avatar
mb1
is there a way to check it to make sure its bad without actually replacing it?
does it throw a code when it goes bad.
Old Jun 26, 2006 | 05:46 AM
nismos14's Avatar
§è~® f®ÈÄk
I would think its one of the coilpacks or a misfire. However that code is somewhat mysterious.
Old Jun 26, 2006 | 05:59 AM
I dont think the fuel pump gives out a code, i havent had experience with a bad fuel pump but if everything else is covered (plugs are good, coils good, Maf good, fuel filter good, air filter clean, etc....) then i would think its the fuel pump and just replace it. I dont know of anything else that would give problems without giving a code, most of the time something like that means its something mechanical and not electrical.
Old Jun 26, 2006 | 07:37 AM
kenju4u's Avatar
if its your fuel pump you should have trouble starting your car too, unless its just starting to go back, in that case the car shouldnt stopped all the time only once ina while even when its on the highway and it will probably start happening more frequently in differnt situations. Then u know its the fuel pump.
with Coil packs u usally experience loss in power, and lots of shaking and codes....
Old Jun 26, 2006 | 10:13 AM
mb1's Avatar
mb1
everything started this morning. no problems before. i have no trouble starting. it does feel the same as hitting the speed governor. could it be the relay?
Old Jun 26, 2006 | 10:45 AM
I think the speed limiter is like a fuel cutoff, so technically it should feel the same as if your fuel pump was dying at certain speeds or rpm. Does any of this happen on the street?
give a lil more detail as to what speeds or rpms your in when this happens. and if your an auto. dont want for you to get paranoid but a bad tranny can cause some very random problems related to what your describing without even showing a single code.
Old Jun 26, 2006 | 01:15 PM
kenju4u's Avatar
well you can check for ATM codes too right? anything there?
Old Jun 26, 2006 | 01:26 PM
mb1's Avatar
mb1
atm codes?
im a manual. im going to attempt to drive it home and see if it throws the light again. we drove it in circles around the parking deck and the only thing wrong was the ide rpms were dropping very low.
Old Jun 26, 2006 | 05:23 PM
Motorhead52's Avatar
I'm guessing the problem is fuel starvation. Changing the fuel filter is the easiest thing, even if you think its good its only a few bucks and most likely to be at fault.
Beyond that, you have to spend some time to diagnose it right. You can try throwing parts at it, maybe its fuel pump, maybe the pressure regulater, maybe the EVAP system, maybe a pinched hose, maybe its not something related to the fuel system after all. You are just shooting darts bilnd folded if you dont take the time to diagnose it right.
Old Jun 26, 2006 | 06:51 PM
MikAus's Avatar
Spend $85 and get the best diagnostic out there, THE DEALER.
If your cars cutting out, that's very dangerous.
It's worth spending $85 at least that way you'll know exactly what it is, instead of guessing and replacing parts that don't even need replacing .
Good luck and stay safe !!!
Old Jun 26, 2006 | 06:57 PM
dartman1's Avatar
Maf
Check your MAF...
Old Jul 18, 2007 | 11:47 PM
dima1086's Avatar
I have almost same problem, i checked at different places, then I went to a dealer, spent 110 CAN, guy told me it could be my tranny, but also i might have problems with this and that, blah-blah-blah... not always they're doing what they suppose to do, he didn't even drive it around like i asked...
Old Jul 19, 2007 | 12:15 AM
funky_monkey58's Avatar
I would take it to a shop and have them hook up a fuel pressure gauge on it see what your pressure is and if it drops off when the engine asks for more gas. If thats the case it could be your fuel pump. Like another guy said it could be your MAF but I have doubts on this one it most likely wouldnt rev up much at all with it out. You can try cleaing it with MAF sensor cleaner. Couldnt hurt.
But I personally would check your pressure before thinking about changing the pump.
As well I believe the maf sensor throws codes so I doubt that one even more.
-Sean
Old Jul 19, 2007 | 05:51 PM
1chewabacha1's Avatar
Check this out. See if the symptoms are similar.
http://forums.maxima.org/showthread.php?t=527891
Old Jul 19, 2007 | 05:58 PM
NmexMAX's Avatar
dot dot dot ...
Anyone notice this thread is 13 months old?
Pulling codes is easy, so...maybe try it before posting. This way, when you DO post, it will be informative enoguh so we can give you the best/most accurate answer.
It took my car 1 week of acting dumb before it finally gave me a code.
Lakersallday24
Jun 16, 2019 01:35 AM
lux97Max
19
Aug 27, 2015 07:48 PM
beboski
Aug 16, 2015 05:23 PM
egali045
Aug 5, 2015 09:02 AM
