Will resurfacing rotors help me...?
I am getting a vibration under braking. It first showed up around 25k miles. The dealer resurfaced the front rotors under warranty and commented pad life was still very good. It went away for about 7k miles and came back, this time a little worse. When I push the brake pedal, it vibrates the steering wheel at highway speeds and vibrates the whole car when just coming to a stop. However, this only happens when the rotors are hot from some stop and go driving. If I get in the car when the car has been sitting for a while the brakes are perfectly smooth at any speed. So now I am beginning to question if resurfacing the rotors again will help, since the rotors are fine when cool and they would be cool when being resurfaced. Any ideas?
it seems like the rotors might be defective somehow... another question is this. do you do a lot of hard braking up to complete stops? one of the things that causes warped rotors is hard braking generating large amounts of heat. then when you're at a stop light stepping on the brake, the brake disc cools, except for the part right underneat the pads which don't cool. the pads themselves are also hot and keeping that section of the disc hot. the uneven cooling can warp a rotor.
-V
Warped rotors
I was having the EXACT same problem with the car...My wheel to shake and "shimmy" everytime I would hit the brakes, esp @ high speeds and make a grinding nosie @ low speed. So i took it to the shop got a Barke Job (Front and rear) and the problem is gone. .........seems like you neeed to get a brake job aslo
I've found that resurfacing rotors on newer cars is a waste of time. The rotors are thin to begin with and after resurfacing they are thinner still and just warp sooner. Replace them, just don't buy the cheap ones, you won't be satisfied.
Try not to make constant hard stops,a good workout is fun, but constant workouts break things. Also remember if you treat your car like a race car, you will have to maintain it like a race car.
Also if you don't have one, buy a torque wrench. Any time the wheels are removed they should be retightened in a chris cross pattern to no more than 125 Ft/Lbs. If you have a shop work on the car specify this.
Overtightening the lug nuts will cause the rotors and sometimes the wheels to warp. A lesson learned over many years.
Good luck
Good luck
Don't overdo it
Originally posted by JohnnyMax
... Also if you don't have one, buy a torque wrench. Any time the wheels are removed they should be retightened in a chris cross pattern to no more than 125 Ft/Lbs. If you have a shop work on the car specify this.
Overtightening the lug nuts will cause the rotors and sometimes the wheels to warp. ...
Originally posted by vmok
you can only resurface so much before you run out of material to take out to make the surface smooth again.
-V
-V
You report "a vibration under braking". Is this felt as a pusation in the brake pedal? A shake in the steering wheel? A sensation of grab-slip-grab-slip from the brakes? Something else? Please elaborate.
Does your Maxima have Anti-Lock Brakes? Has it ever been in an accident? Have you rotated the tires as a diagnostic measure?
The rotors may be measured with a dial indicator gauge to determine if they have excessive runout (warpage). They may be measured with a micrometer to determine if they have excessive thickness variation. For further information, please refer to the Chilton repair manual, page 9-11.
i had the exact problem with my brakes. All i had to do was have all 4 of my rotors cut and the problem has been gone since! I also reccomend ceramic brake pads for up front, they produce 1/2 as much dust and seem to bite better on the rotor. hope this helps!
Originally posted by Daniel B. Martin
I can't explain why the symptom is evident only when the brakes are hot. A careful inspection is needed to uncover more clues to this mystery.
Apr 16, 2020 05:15 AM
