Shorted out door light, don't know where. Help!
Old Jul 3, 2006 | 02:10 PM
Powerman5115's Avatar
I was checking which prong was positive on the door light and accidentally hit the negative and positive at the same time and I heard a spark. Now the light doesn't work. It shorted out something, but I do not know what. I swaped the light assembly from the other door and it did not work. I checked the fuse and its not broken, and it is still getting power to the light bulb. I don't know what is wrong with it. Please help me.
Old Jul 3, 2006 | 02:20 PM
Hexon's Avatar
So the light fixture still works, but the bulb isn't lighting up? Am I understanding right? Sounds like a blown bulb.
Old Jul 3, 2006 | 02:27 PM
The light fixture is getting power but the bulb doesn't work. It's not a blown bulb because the bulb on the other door that works did not workin in this fixture. I just found out that power is restricted. It works with one LED; but I'm not sure how to fix this.
Old Jul 3, 2006 | 07:49 PM
200kMax's Avatar
im surprised noone answered..
anyways, same exact thing happened to me. and as other ppl have told me, it definitely is the power window switch that caused this. it is the red/white i think. trace it and it will go to the power window switch. internally there is a circuit that trigures a ground. the hot wire, (red/blue or yellow) (dont remember always should get power.
or u can do what i did. instead of changing the switch, wire a new ground from the other door that works and tap into that ground.. its more work but cheaper than getting a new switch.
Old Jul 3, 2006 | 09:00 PM
Black Maxima
Window switch FTL...
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
