Replaced knock sensor and injector, now wat?
I just got done replaceing a rear injector and the knock sensor. Got it all back together, no more check engine light. But I have a intake leak or something. Sounds like its comming from the front of the plenum but i loosened it up and re-torqed it. Still a leak. I am really hoping its not the intake manifold
Spray around the area you think is leaking with carb cleaner (stay away from plastic) and see if the leak stops hissing and the idle improves when you spray one spot (this is leak). Alternatively, put a plastic tube in your ear and run it around the area and see if you can hear the leaking spot.
Cracked vacuum tube? Disconnected vacuum tube?
How does the car idle? does it idle alright or does it just want to die after a few seconds of running it? Also is there fuel everywhere? if you pinched the O-ring, then there would be fuel everywhere ( something I did when i pulled off my plenum and put the injectors back in incorrectly)
Originally Posted by probmxstyle
it would idel for a second, but very rough. It would sputter and want to die if i didnt touch the gas. Also it would shot smoke and gas out the tail pipe. I fixed it the other day none the less.
Well, it sounds exactly how my maxima acted when i messed up. I didn't torque the lower manifold down correctly. It was tweaked and i had an air leak. glad to hear to finally got it fixed.
Well it only smoked for a min or 2. When i drove off it gradually stopped and it hasent smoked for the last week since i worked on it. So i am guessing its ok right?
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
maxinout93
Aug 20, 2015 02:17 AM
