Driveshaft on a I30 and I30T
Wanted to make sure the 97' I30T is the one with the diff, and that the I30 is the model without the diff.
B/c im not sure which axle i need for my I30 base model.
Can ne body confirm this real quick.
the "T" models came with the limited slip differentail AKA High Speed Differential
Plain models did not.
BTW it is also noted on the plate on the firewall as well
O yeah I checked the model number and it does have an LSD..
, but now the drive-axle seal is leaking.
Both have a diff. The issue is wheater your car has a limited slip diff which uses a different differential side oil seal (larger). All ts have the lsd. Non ts might or might not have it. Check your firewall plate to find out.
Well, I didn't used to.. 'til ~120k miles. Took it to infiniti and explained my problem, he said that was the cause. I thought it was my wheel bearing but I still have it after the replacement. New tranny replacement is somewhere in the range of 2200 dollars so I'm trying to see if anybody has the same issue.... and so far, I think i'm the only freakin' one.
jerrod99_se-l
Sep 25, 2015 03:02 AM
