Cattman suspension on order
The time has come. I placed an order with Brian Catts on Friday. Very nice and knowledgeable guy and pleasure to deal with.
We will be getting 4 Springs, RSB and full set of 4 KYB GR2s. Should be here sometime this week. I can't wait. I will keep you guys posted.
Kamski
I have the same setup, minus the struts on mine, which are on the way... I recieved 1 front and 1 rear strut so far. I really wish I knew what's happening with the other 2 struts. But I may sell them and get coilovers instead.
Originally Posted by kamilkluczewski
Should have asked if he can mount the springs on the front struts for you......... That would save you an hour worth of work.
Kamski
Kamski
CM
Did you do the brakes yet?
Originally Posted by CanadianMoFo
Get the Raceline endlinks for your new RSB while you are at it. They are in the group buy section for something like $45USD.
Also I was wondering if you would recommend a suspension set-up since you're very knowlegeable on the subject. I drive the Max in the winter...not much but still some. I would like a set-up where I can lower it in the summer and raise it in the winter (at the dealer...they're pretty good!) with out affecting the ride quality too much. I was thinking of a set of (4) coil-overs. I know that raising them and lowering them is a B$%#tch however do I have any other choices other than stealing a Mercedes's magnetic height adjustable suspension set-up! LOL!
Any advice would be greatly appreciated. Thanks!
BTW, i need to change these old photos
Originally Posted by xorbitman
Hi Canadian ****, Did you do your brake pads and Rotors yet?
Naw. Still using the OEM stuff for now. I had them replaced under warranty around the 2 year mark. So I'm likely good for another 2-3 years since I'm not using it in the winter.
CM
http://forums.maxima.org/showthread.php?t=479131
$215 for all 4.
$215 for all 4.
$495 for the entire suspension set consisting of:
4 KYB GR2's (front and back)
4 Progress/Cattman springs (front and back)
1 Progress/Cattman Rear Sway bar
Let me clear the confusion about Progress/Cattman deal. Cattman devloped the springs (with help of Deus if remember correctly) and progess is making them for him.
I bought two sets of these for myself and my brother, we also got two sets of racing endlinks. RSB and springs already arrived. Front struts and rear shocks are still on the way. TAZ is supposed to send endlinks this week so I guess we'll do the whole install in about two weeks. We'll keep you updated and I hope all goes well with our mechanic dude installing it. I can build a computer or two but when it comes to auto work I'm GREEN
Originally Posted by Ankit69
just curious are you usin your stock tires in alaska?
There is a tread relating to this one. You may want to see whats up. it was started by someone who already received and installed the set.
http://forums.maxima.org/showthread....=1#post5145130
Finally got everything installed:
KYB GR2 - all around
Cattman/Progress Springs - all around
Drilled/Slotted Rotors - all around
Hawk HPS pads - all around
SS Lines - all around
Cattman/Progress RSB
The car feels and handles amazingly. It is just a tad stiffer but so solid all around like a brand new car. I haven't done any hard manuevers yet. I will on the way home form work. So far feels like a brand new car.
Originally Posted by BadBlackMaxSL
Looks nice, it doesn't look like the rear is as low as DRU 1's, I wonder why? I like your wheel gaps, they look even.
Indeed, the other guy's car looked lower in the back. Hmm, why is that?
Originally Posted by DRU1
it prolly cuz he dont have a heavy speaker box....if he does then i would have to say HMMMMMMMMMMMMMMMMMMMMMMMM
Originally Posted by xoomer.com
That doesn't make sense. If it looks this much lower just because of a speaker box (which is not really heavy) What that hell is going to happen when you have 3 200Lbs individuals sitting in the back. I mean, is this designed so that you don't carry anything in the trunk or the back seats. Maybe some of us here have the car for themselves only but then there are other that sometimes have to have 5 peeps stuffed in the car.
mroleg....did you take a before and after messurment of your car to see what the actual drop was?
Dru's back looks lower on before picture than it is on mine before picture. I guess it is a heavy *** sub.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
bigfrank
Oct 1, 2015 12:51 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
