Battery and Brake Light Displayed At Same Time
Old Jul 30, 2006 | 10:22 PM
Wreck-Diver's Avatar
Hi everyone,
My 01 Max's battery warning came on last night... about 30 seconds later, the brake light came on. I was about 50 miles from home, and it was night time, so I turned off the fog lights, radio and AC... also dimmed the console. When I got home the battery had 10.2 volts. Seems like a charging problem, but I wanted to see if anyone else has had this problem, and what the cause was.
I fully charged the battery, and the lights are still on. The brake system is in good shape, with plenty of fluid. I have 80,000 miles on the car.
Thanks in advance for the advice!!
Regards,
Wade
Old Jul 31, 2006 | 12:25 AM
† ErV †
bad alternator.
Old Jul 31, 2006 | 01:47 AM
AceofSpds's Avatar
wat
Originally Posted by † ErV †
bad alternator.
its your alternator time for a new one.
Old Jul 31, 2006 | 02:27 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
bad alternator... autozone $220.00 have fun with installation
follow this if you want to install it yourself
http://www.motorvate.ca/mvp.php/500
Old Jul 31, 2006 | 06:58 AM
Awesome... Thanks for the reply!! THANKS Lontar1 for the link... it will help. I am going to go ahead and replace my belts while I am at it. Thanks again!!
Old Jul 31, 2006 | 07:30 AM
MacGarnicle's Avatar
replacing the alternator looks like it'll take hours! all the more reason to do it yourself I guess.. lest the dealer suck you dry. anyone know if this job would be easier if you did it from the bottom of the car?
Old Jul 31, 2006 | 08:39 AM
9DTALON's Avatar
It is removed from the bottom, but some work will need done up top first. Should be about an hour job with hand tools. If you are spending 220 at autozone I highly recomend spending 270 and getting a Nissan reman from the dealer. After doing this job you won't want to be re-doing it in three months. The only re used parts in the Nissan alt is the casing. Just my opinion. Good luck.
homeyclaus
Sep 3, 2015 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
Samedi
Aug 13, 2015 04:05 PM
Superbform
Aug 11, 2015 08:10 PM
