sounds like I have a BOV!
not too sure what is causing it, but if I have my A/C on and I'm at full throttle (or pretty close to it) and the car shifts, it goes PFFT!
is there a pressure bleed valve on the compressor that kicks in?
right now I sound like a ricer
seriously, you dont know what it is??? u know everything................
lol it does kinda sound like a bov, actually more like a belt squeel for 1 sec
if ur ac is on, and ur at WOT, the compressor turns off, for more power
so when you shift it kicks iback on really hard, thats what it is, i do it all the time.
but seems like it would be really hard on the ac clutch, it kicks in at like 5k rpm, cant be good for it.
wow how did i know that, idk i think i read it in the FSM
Dude you should be thinking of a way to amplify that sweet sound...
BTW My friends old Sentre SE-R made a supercharger sound when his engine would wined down, it turned out to be the alternator was going bad. It had a fairly high pitched sound which kinda sounds like a BOV. Not sure, it's your car you know more then I about where the noise is coming from.
I'm at work with no FSM handy to check if the compressor has a pressure relief valve.
BTW I did know about the compressor cut out, it's pretty common on most cars. But I've never heard the PFFT sound on any of my other ones.
I'm just worried about losing R12. I don't want to put R134a in my car.
Mine did the same exact thing before I got the UDP.
I wasn't sure if I was loosing r12 or not, so I would always hit the AC button off when I thought I was going to rev it hard. My AC still blows cold, but I haven't had that problem since I put on the UDP. I guess you need to get one
give me yours
That will be $4200* and I will throw in the Maxima for free.
*does not include shipping to Chicago
The engine was installed by Jeff92SE -- that right there makes it like gold. I am practically giving it away...
Originally Posted by MrGone
Mine did that too
Fidanza/UDP/etc
Kinda funny considering the AC should be off at WOT. I never bothered to check it out, I blame the ricer in me.
Fidanza/UDP/etc
my stealth sounds like it has a turbo... but it doesnt.....i dont know if there was a bad weld on the exhaust, but it whistles VERY loud at 3000+ RPM..... and when i let off the gas, it also sound like i have a BOV..... but i dont..... i really wanna know what is causing that..
dude there isnt oe thing right on my car.. the ECU is going bad... i am running on 5 CYlinders...(should have fixed the maxima), passenger regulator is bad....slave cylinder is not holding pressure...... ohh and i just got into an accident on my birthday......i need a front bumper cover, a eice of metal behind that... a fender, a hood, and headlight.....
it will all eventually get fixed......it is a good thing i work at a mitsubishi dealership... HA HA
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
