Does anyone know hot to upgrade the interior lights to blue?
i want to change all the interior lights to blue.
i was told they are LED's, but is it plug and play
or u need to solder?
I ordered a blue one for the dome light from somone on here, u can custom make one too, its in the stickies, and for the doors just get blue LEDS size 194, dont get the none led type cause they look green. good luck, ohh and cefiro sills look mad good with this interior
If you are going to change "ALL" interior lighting to blue, then yes, you do need to solder. Things like the window switches, a/c control, hazard button, defroster, security light, dimmer switch, etc all have LED's in them so you would have to desolder them and replace it with what ever color you want.
For the rest lilke the dome light, map light, door light, gauge cluster, you can buy leds that are in the shape of that bulb size and it'll be plug and play.
speaking of map lights/dome lights
i just bought this Luxer1 style 12-LED LED Interior Dome Light from http://www.ijdmtoy.com/webpage/products/panel.htm
I hope it works!
DOES ANYONE KNOW WHERE TO GET ONES TO REPLACE FOR THE MAP LIGHTS? I CAN'T FIND THEM ANYWHERE!!!!
PERHAPS NOT EVEN LED BUT JUST BLUE ONES IN GENERAL? THE WHITE ISNT DOING IT FOR ME.
no they don't. You should be buying them online if you want leds. You should be soldering led's intot he swithces and all if you want an upgrade. Not the $5 ones from radioshack or whatnot. Do some research guys. It's been covered way too many times.
rbaker100
Aug 28, 2015 08:11 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
ER!!!!!!!!
