mileage is getting worse and worse
Old Jun 24, 2001 | 12:50 PM
serin's Avatar
any ideas? the only performance mod i've done is the oscai, and that was put in a while ago.
i was gettin 23 mpg every single tank, regardless of highway or city. then it creaped down to 22, now it's at 20 mpg. no recent mods, and again, it doesn't matter if it's highway or city driving.
my method of calculating is simple. i reset my tripmeter every time i fill up. then the next time i fill up i just divide the number of gallons into the number of miles on the tripmeter.
my warranty's almost up so if i have to go to the dealer, i wanna go soon. any ideas on what should be checked?
Old Jun 24, 2001 | 12:57 PM
MaxedOut2g's Avatar
i know what u sayn man; except i have never got higher than 20 mpg...when i first got my car, i got bout 320 miles after 16.5 gallons..ive tried to use different types of gas,first w/ arco, then 76, then mobil, and cuz nothing seems to work, im going w/ Costco gas, currently at 1.85 for 92 octane, and i just started an internship, and the roads to get there have speed limits of 35-45, so im pushn between 1.5k and 1.75k rpms constantly, and i only got 20 mpg.......oh yea,no performance mods either, not even OSCAI, (( which btw if sum1 in So Cal [Diamond Bar, Puente Hills, Chino Hills, Walnut...] area can help me put in, would be apprecaited cuz im scared as F*** to try anything w/ my car... ))....this really sucks
A_T_W
Old Jun 24, 2001 | 01:02 PM
serin's Avatar
A_T_W
i'm in fullerton. my girl's in walnut. my church is in hacienda heights. so i'm in the area. email me and we can set something up.
Old Jun 24, 2001 | 01:07 PM
irvine78's Avatar
maybe time for oil change and tune up....hehe...
Old Jun 24, 2001 | 02:15 PM
stevepake's Avatar
1) Check tire inflation
2) Clean air filter
3) Put a bottle of fuel injector cleaner in your Max on the next fillup.
4) Be sure you're using PREMIUM 91+ pump octane fuel and not regular 87.
You could also try removing the OSCAI and going back to the stock setup and see if your mileage improves to where it was before. That would isolate the OSCAI and see if that's affecting your mileage as well.
But definitely check #1. If you've got just one tire that's low on pressure it'll massively increase the rolling resistance and send your mileage down the toilet. You'll get about a 1mpg increase for every 2psi of inflation you crank up your tires by, generally. The stock pressure in my Accord is 29/30psi F/R, but I have them cranked up to 34psi all around to boost up my mileage on my 95+ % highway driving and it's definitely helped.
So give all those a try
Old Jun 24, 2001 | 05:01 PM
serin's Avatar
2) Clean air filter
thanks, i'll check the pressure today. as for the other stuff, i use 92+ only, i use fuel injector cleaner every other tank, the filter is K&N with about 2000 miles on it, and the oil is definitely new.
Old Jun 24, 2001 | 09:34 PM
MaxedOut2g's Avatar
hey Serin, i dont know if u've checked yet, but i sent u a private message bout the OSCAI installation and stuff
A_T_W
Old Jun 24, 2001 | 10:13 PM
TimW's Avatar
The silent but deadly Moderator
ummmm
dont use any injector cleaner without asking the dealer first. Nissan injectors dont like cleaner and it will damage them. If you must, there is a ratio that is acceptable. the dealer can tell you, and even give you some 'approved' cleaner. As I remember, they said that I could use 1/2 dose of what they had, or like 1/4 dose if I picked up something off the shelf, but they really didnt want me to do that...
A woman at work pumped some into her nissan and had to have her injectors rebuilt.
Old Jun 24, 2001 | 11:58 PM
irvine78's Avatar
Re: ummmm
yeah, i think he's right.
especially these new cars are not suppose to take in that much injector cleaners....it's actually bad for the engine..
Old Jun 25, 2001 | 12:03 AM
serin's Avatar
oh....
that's news to me. i guess i'll just save my money. good thing you told me.
Old Jun 25, 2001 | 12:33 AM
stevepake's Avatar
Re: Re: ummmm
Well geez, ya learn something knew everyday I guess!!! I'll have to see what the book says for my Accord before I dump a bottle in...
Old Jun 25, 2001 | 07:43 AM
2001SE's Avatar
In the Nissan Maxima manual it says not to put any of those fuel cleaner, fuel boosters, etc.
Old Jun 25, 2001 | 08:29 AM
Paul6speed's Avatar
20 is good. I think Consumer Reports got 21 in their test cycle. I usually get 18 city/. On the highway I can get up to 28, but usually get around 25. In the winter I was lucky to get 23 on the highway. Now that summer is here I'm doing much better. Might have something to do with different formulations of gas and temperature. There are something like 30 different formulations based upon region.
Old Jun 25, 2001 | 01:11 PM
serin's Avatar
AAAHHHH. didn't know that. i guess you do learn something every day.
Old Jun 25, 2001 | 01:14 PM
UMD_MaxSE's Avatar
Got Bent?
gas in colder regions is oxygenated during the winter time. This will cause you to lose a few mpg in mileage. When the temperature gets warmer, they switch to regular gas...
Old Jun 25, 2001 | 02:52 PM
bootone's Avatar
I can relate
I get awful gas mileage too. When new I was getting 23 - 24 city and 26 28 hwy.
I drove to ATL this past weekend and at 320 miles I had 1/4 of a tank. Something is awfully wrong and the dealer see's no problem. My problems acts the opposite of the fuel cut problem. When I let off the throttle you can feel the car pull more than normal. Hard to keep it at a steady speed
I have tried as the old folks say "High Test", inflating tires, driving moderate speeds, the car does'nt have the power it used to have. I think I will sell it..........
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
dshinn
Sep 26, 2015 08:07 PM
