car drives like CRAP?
Old Aug 11, 2006 | 04:03 PM
moogotzskillz2's Avatar
hey whats up yea'll
well for the past 3 days i've been driving my maxima, since it's been sitting for like 2months*rockin my winter beater*. so its been drivng like CRAP liek when i get up on it, it starts to LAG like its about of gas. and i got a SEL so i check'd it and it said "random misfire" i did a full tune up before i let it sit (except coil's) but my ? is that do yea'll think that its my coil????? but it wasnt liek that after i did my tune up, could it be like a common thing out there???? thanks in advance to all...
-moo
Old Aug 11, 2006 | 04:07 PM
kcryan's Avatar
test the coils per service manual
Old Aug 11, 2006 | 04:09 PM
DaGGer's Avatar
well lag would usually be a fuel filter or something. But driving like crap would be the ignition.
Old Aug 12, 2006 | 02:35 PM
nitink's Avatar
I am facing the same problem.
DOes your car have clean gas ? Maxi's fuel injectors are worst in world, they clogg so easily.
DO the following
1) Replace your old gas
2) Put in chevron techryon and new gas and drive at highway speed (> 80mph)
3) if car still roughits probably ign wires or some senor
4) I would check wiring of TPS & TPS it self (its easy to check)
In my case I found TPS was bad but no code, may be it was at last stage of its life so no code.
Do let us know what you found.
Old Aug 12, 2006 | 02:40 PM
nitink's Avatar
I don't have permission to start a new thread, So I am posting it here hoping some one could answer
My 95 maxima GLE, seems to have brain of its own
1) Engine rpm changes by it self without me giving any gas or applying breaks.
2) Car sometimes dies after it coming to stop
3) In neutral Car cannot go above 2500 RPM.
4) I have TPS bad & Knoc sensor codes, changing tps did not helped
Any help is really appriciated.
Old Aug 12, 2006 | 02:53 PM
asianpr3082's Avatar
you might have a leak in the maf sensor area check your pipes and vaccum lines. check good a maf sensor is mighty expensive
Old Aug 14, 2006 | 03:20 PM
nitink's Avatar
Thanks, MAF area is the problem, Probably MAFi s going.
I am wondering if I can fit MAF from other nissan models in 4th gen. New MAF is very pricy, But I can get old one from 240 or ser for like 10bucks.
Does anyone know about other models MAF which can fit 4th gen without burning a hole in pocket.
Nitin
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 9, 2015 11:50 AM
yat70458
Aug 3, 2015 01:16 PM
