Having Trouble Removing Rotor From Car!!!!
I removed the caliper, break pads, and shims. But I cannot get the rotor off. its suppose to come right off? Im having trouple getting it off. Any suggestions on how to take this off? I have an 01 max se.
In the past while i was working on brakes, I have found that if the rotor won't come off, you can bang on it with a rubber mallet. Not hard enough to break it, but hard enough to knock it loose. I am not suggesting that you try to hit the rotor from teh back to knock it off, just bang on the face of the rotor a little. If that doesn't work then I don't know what to tell you.
there's also a couple threaded holes on the back of the hub where you can thread a matching bolt through, which pushes the rotor out....try the rubber mallet first (worked for me) and if you still can't get it off, try threading a bolt throught those holes
These non rust people have no idea how bad it can be for us. YOu will jsut need to beat on it with a hammer, I end up using a sledge. spray behind, pound, and annoy neighbors.
those stupid screw threds just rip out because the rust.
Greg
Greg
Greg
Greg
Originally Posted by NeverBepeace
What kind of rotor should I get? I know pep boys have them for $24.99. Should I get those?
Brembos will last a long time if you keep your lugs properly torqued.
I just used a hammer and would spin mine a little as i banged on them from behind...that way you dont put too much lateral stress on the wheel hub bolts. If you see rust dust coming out from the hub bolts...it's working..keep banging...but some muscle in it man.
Here's my tips
http://forums.maxima.org/showthread.php?t=469787
Greg
Greg
I tossed the rings and haven't really noticed any more vibration. Not worth going through that again.
And yeah, the front rotors rust like mad as well.
Lakersallday24
Jun 16, 2019 01:35 AM
03VQMAX
Sep 25, 2015 04:19 PM
kirkhilles
Aug 8, 2015 10:53 AM
RealityCheck
Aug 5, 2015 06:18 AM
