easy way to tell if car has an lsd?
Old Aug 13, 2006 | 08:13 PM
kobalt's Avatar
Gentlemen, Im going to look at 3 different 6sp Maxi's tomorrow. Is there any way to easiely tell if the car is equipped with an lsd? I mean without lifting it or driving and looking for torque steer? A special serial number or some sticker perhaps? Thanx guys.
Old Aug 13, 2006 | 08:18 PM
SEmy2K2go's Avatar
Go BUCKS!!!
This was posted by Puppetmaster in a similar thread.
Pop the hood and look at the transaxle code on the firewall. If it ends in "H" the car has HLSD and if it ends in "A" it does not.
Old Aug 13, 2006 | 08:22 PM
MxdOut97's Avatar
silver drilled pedals come with the hlsd, although some people put them on non-hlsd cars as well to so be careful
Old Aug 13, 2006 | 08:26 PM
AceofSpds's Avatar
wat
Hehe or you could lay down some rubber and see if you leave 2 markings , or if you floor the gas im shure if you have torque steer there's no lsd.
Old Aug 13, 2006 | 08:33 PM
kobalt's Avatar
I've been out of the loop for a while, sorry As always, thank you all. One can always count on the maxima.org guys
Old Aug 13, 2006 | 10:04 PM
KBADPAT's Avatar
Not necessarily. Some member claimed their cars came with AE pedals but no HLSD.
Andrei
Old Aug 13, 2006 | 10:12 PM
AceofSpds's Avatar
wat
Andrei
Thats what he is stating.
Old Aug 13, 2006 | 10:31 PM
KBADPAT's Avatar
Yes, the other possibility. But some Maximas come from the factory with silver pedals although not being equipped with HLSD.
Andrei
Old Aug 13, 2006 | 10:37 PM
AceofSpds's Avatar
wat
Andrei
I thought that was on the AE cars not the 02-03's i could be wrong tho, but i do remember reading about cars that came w/ the pedals without hsld now that i think about it.
Old Aug 14, 2006 | 01:03 AM
sciff5's Avatar
Jack the front of the car up and spin one of the wheels. If the other wheel doesnt move or turns in the opposite direction its an open differential, and if the wheels turn together in the same direction than it has a LSD
Old Aug 14, 2006 | 01:11 AM
SEmy2K2go's Avatar
Go BUCKS!!!
^^^ that'll be kinda hard to do when he's checking out 3 different cars tomorrow.
Old Aug 14, 2006 | 02:13 AM
Puppetmaster's Avatar
That isn't a good way to tell because the helical only works when torque is applied to the ring gear itself. The wheels spin independently even if the car is HLSD equipped. I've tried it. I've also verified my transaxle code and called Nissan to confirm. Checking the transaxle code under the hood or calling Nissan USA with the VIN to get what options the car from the factory with are the 2 easiest ways.
Old Aug 14, 2006 | 05:23 AM
KBADPAT's Avatar
The most efficient way would be by the VIN# end of story.
Andrei
Old Aug 14, 2006 | 07:14 AM
MWilds 01 20th's Avatar
Is my AE LSD??
Old Aug 14, 2006 | 07:42 AM
burnurass's Avatar
Originally Posted by MWilds 01 20th
Is my AE LSD??
vlsd i think..
Old Aug 14, 2006 | 07:47 AM
Is my AE LSD??
If your transaxle code is RS5F50V then it has VLSD, as stated above. If it is RS5F50A then it is open differential.
Old Aug 14, 2006 | 08:12 AM
alpinestars™'s Avatar
THIS IS...
Mine is RE04F04W. But I thought ALL AE's came with LSD. I guess I got screwed...
Old Aug 14, 2006 | 08:43 AM
that's because you have an AT.
The AT VLSD code is RE4F04W.
http://forums.maxima.org/general-max...00#post3818100
See also:
http://forums.maxima.org/infiniti-i3...-info-fyi.html
Old Aug 14, 2006 | 09:33 AM
THIS IS...
Yeah I forgot to mention I had AT.
Thanks Puppet, helpful as usual.
Old Aug 14, 2006 | 08:17 PM
kobalt's Avatar
Thanx again everyone for chiming in. Alas, no lsd The price was to good to pass by however and I will be picking her up on Sunday.
Old Aug 14, 2006 | 08:22 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Congrats! Details
Old Aug 14, 2006 | 09:20 PM
kobalt's Avatar
Originally Posted by SEmy2K2go
Congrats! Details
Thanx! Details/pics on Sunday since I have to wait until then for the $ to clear
Old Aug 15, 2006 | 08:07 AM
shurik's Avatar
Excuse me guys but what the %$## is HLSD??????????? hehe
Old Aug 15, 2006 | 08:12 AM
http://forums.maxima.org/showpost.ph...4&postcount=60
Old Aug 15, 2006 | 08:41 AM
amimaxima
do a burnout that will tell you what you have
Old Aug 15, 2006 | 08:50 PM
ryant35's Avatar
I'm sure the guy he's buying the car from would love that, just lay a couple of patches of rubber and say thanks but I'll keep looking.
Old Aug 15, 2006 | 08:51 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Great advice
Old Aug 16, 2006 | 08:17 AM
beancooker's Avatar
OK, called Nissan USA and they could'nt answer, called the dealership and got 4 different answers, in the end they don't know. So my transaxle code is RE4F04B. It's an automatic. It leaves 2 tire patches when you burnout. Does anybody know which transaxle this is?
Old Aug 16, 2006 | 10:03 AM
See post #18. First link.
Old Aug 16, 2006 | 11:40 AM
amimaxima
Great advice
it was wasn't it
Old Aug 16, 2006 | 11:41 AM
beancooker's Avatar
Thanks puppetmaster, my question then is, why do both tires burnout, luck, lack of torque, or something else I don't know about?
Old Aug 16, 2006 | 08:38 PM
Derrick2k2SE's Avatar
All is not lost. You can always track down a tranny with HLSD and swap.
I found one in Canada from an 04 car. It was like $850 to my door. I did the swap and sold the old tranny to a shop for $150. It was a huge improvement. I used to spin all through first gear, spin shifting into second then sometimes spin again when I hit about 5000 PRM in second. Now it hooks so much better and is easier to keep traction once it hooks. All these cars should have come with HLSD.
Any way, the point is for not much money you can get the HLSD.
Old Aug 16, 2006 | 08:43 PM
kobalt's Avatar
I can't imagine the swap being easy without a lift, but it's good to know that a swap is a feasable option. Thanx for your imput.
btw, how is that light flywheel working out?
Old Aug 16, 2006 | 10:58 PM
The tranny swap isn't easy but it's not too bad even on jackstands. I've had the tranny out 4 times this year for various reasons. I've got the hang of it now.
If you do consider a swap try to get a tranny from an 04 car. They improved the syncros for smoother shifting and they don't get the 3dr gear grind that a lot of the 5.5 gen manuals have. It's still a direct swap.
I really like the light flywheel. I've gone back and forth between the Fidanza and stock and back to the Fidanza. The Fidanza feels like driving the car alone with an empty tank. Going back to stock feels like the car is weighed down with a full tank and a few passengers. I could definately feel the difference.
Old Aug 17, 2006 | 09:45 PM
kobalt's Avatar
The Sentra SE-R tranny could bolt up, right? According to the fsm it has better gearing as well as hlsd. That would kill two birds with one stone. Plus it runs a bit cheaper...
Old Aug 18, 2006 | 03:03 AM
See this discussion.
http://forums.maxima.org/showthread.php?t=486834
Old Aug 18, 2006 | 05:20 AM
boondoxmax's Avatar
This is a copy of my transaxle plate in my 6 speed and it has HSLD
And the inside of the car with the drilled pedals
Old Aug 18, 2006 | 01:59 PM
kobalt's Avatar
Puppetmaster - thanx for steering me in the right direction!
Boondoxmax - I assume drilled pedals = hlsd?
Old Aug 22, 2006 | 02:39 PM
kobalt's Avatar
I finally picked up my Maxima yesterday for a final price of $10700. It's a burgandy 2002 SE with 62k miles and no options to speak of.
Origianlly we agreed upon 11900 but in their ineptitude the dealer sent the title to Linden OH not Linden NJ - this caused a one day delay and as such I could not pick up my car Sunday and lost a day of work as well. This made me a bit upset and to make a long story short a few not so kind words with the general manager went a long way in terms of price, new brakes, tires and battery.
Old Aug 22, 2006 | 02:43 PM
AceofSpds's Avatar
wat
very nice man... talk about a deal, most people pay that much for a 2000 w/ the same milage
