Any advice before swapping out my LCAs?
I'm going to be doing LCAs on the turbo car tomorrow assuming the weather cooperates, because it needs new ball joints. I purchased the $75 LCAs from http://www.internetautomart.com/ so hopefully they came with better ball joints than the thread i just read in the 4th gen forum about someone's ebay ball joints failing in 4 months
Any advice anyone can give on special techniques, things to look out for, etc? I'll have to pick up a ball joint removal tool from Sears or a parts store if I can locate one to rent/borrow.
don't worry about the ball joint remover tool.. just unbolt your axle and strut assembly.. get the axle out of the way, then unbolt the ball joint and smack the top with a hammer. pops right out.
either that, or I've left the axles in and stuck a small piece of scrap metal above it and unscrewed the nut on the ball joint until it presses on the steel scrap and pushes the joint out. both easy/free ways to get it done if you don't have the tool.
I've also used a two-jaw puller before, but that again assumes you've got the axle out.
or the redneck way to do it is to just pound on the knuckle with a hammer and after a few good whacks, the joint till just fall out of the knuckle.
Originally Posted by 97SEdriver
any reason you're not just putting in ES bushings?
Anywho thanks for the advice guys, I've had it done for like 3 weeks now lol. air tools > need for lube and breaker bar hehe.
I don't understand the question... I didn't even mention bushings in this post. the car needed new ball joints.
Ok... the way you worded your post it sounded to me like you were suggesting that just replacing the bushings would solve the problem I was having with my ball joints. Your juse of the word "just" is what threw me off.
any reason why you're not just installing ES bushings?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
