I30 Check Engine light P1445
Old Sep 2, 2006 | 05:02 PM
Mikey535's Avatar
1996 I30
i just pulled check engine code: P1445
how can be fixe? any help will be usefull.
Thank you very much!
Old Sep 2, 2006 | 07:05 PM
i30ds's Avatar
Armed and Dangerous
P1445=1008 which is an EVAP code. Reset your ecu and then see if it comes back. If id does then you'll need a chiltons and a multimeter to do some diagnosis work.
Old Sep 2, 2006 | 07:41 PM
Mikey535's Avatar
i reseted the ECU, and code came back..
do i need to replace part and where is EVAP locate at..
Thank you..
Old Sep 3, 2006 | 10:16 AM
KRRZ350's Avatar
evap stands for evaporative emmisions, gas fumes can't be let into the atmosphere, they have to be stored and purged into the intake so they can be burned off. Common spot for problems on the 4th gen is under the car, in front of the gas tank, behind the rear door on the drivers side you'll see a little black plastic cover, look above it and make sure there isn't a problem with the hoses first, then get a manual and go from there.
Old Sep 3, 2006 | 11:36 AM
i30ds's Avatar
Armed and Dangerous
check the ecu sticky in the 4th gen stickies. It will tell you how to test the valve to see if it is functioning properly.
Old Sep 3, 2006 | 11:41 AM
Mikey535's Avatar
i check the hoses.. it looks fine.. i don't see any leakage..
Where is purge volume control valve locate it... ?
i can't find chiltons or Haynes repair manual? should i buy maxima repair manual...?
please provide me with more information...
thanks
Old Sep 4, 2006 | 06:26 PM
i30ds's Avatar
Armed and Dangerous
Malfunction is detected when:
A) Improper voltage is detected from the valve by the ECM. Check items: harness, connectors.
B) Canister purge flow is detected during specified driving conditions even when EVAP canister purge volume control valve is completely shut off. Check items: EVAP control system pressure sensor, EVAP canister purge volume control valve (valve is stuck open), EVAP canister purge control valve, hoses (connected incorrectly).
The EVAP canister purge volume control valve is located behind the throttle cables above the intake manifold.
Get the Maxima Chiltons/ Haynes manual. You're gonna need it.
Old Sep 5, 2006 | 07:26 PM
Mikey535's Avatar
EVAP canister purge volume valve parts...
okay... i need to purchase this EVAP canister purge volume valve..
someone please provide me with part #'s and place where i can get this low pirce...
Than you all.. again..
Old Sep 6, 2006 | 04:46 PM
i30ds's Avatar
Armed and Dangerous
Sent you a PM.
Old Jan 4, 2012 | 10:53 AM
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by ingrid
very reasonable price for certified used parts
Kilt. Thanks tigershark
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
