turbo problems
Old Sep 10, 2006 | 05:44 PM
wunfstmax's Avatar
turbo problems
Background I blew the engine about mid-late June, so I went and got a new motor. While the car was down I decided to switch to a forward y pipe set up, got rid of the hks 40mm wastegate and got a 38mm tial, switched from a .81 turbine to a .58, and went from stock injectors to 450cc.
The problem. Of course the car spools alot faster, but I'm only seeing 1-2 psi on my boost gauge(the only source that I have for a reading). So I check for leaks and the couplers, and havent found any. I made sure the manifold bolts were tightend. Hooked up a home-made boost leak finder, but it broke. The wastegate hasn't opened(still clean).The turbo is a to4e unit from turbonetics.
This would all be fine if it felt like it was up on proper power, I would just determine that my boost guage took a dump, but its not very powerful at all.
Im at 6000+ ft in elevation, but I'm getting my source before the manifold, at the manifold the needle doesn't even move.
Furthermore, when I hook up my rpm source for the emanage it makes the car run like ****, kinda like it has a blown mafs.
Any help would be appreciated.
Old Sep 11, 2006 | 09:20 AM
Bags's Avatar
VG Ridah's Biatch Hoe
What size spring is in the wastegate?
Have you tried getting a boost reading from the turbo itself?
Old Sep 11, 2006 | 11:41 AM
wunfstmax's Avatar
wastegate springs is 7.5lbs. Ive tried to get one from the turbo, but the hose isnt long enough.
Old Sep 11, 2006 | 07:12 PM
Bags's Avatar
#1 buy more hose. You can use cheap rubber hose from autozone/pepboys/etc
This will tell you what your turbo is putting out
#2 is your BOV working properly?
Old Sep 11, 2006 | 08:23 PM
wunfstmax's Avatar
I found some laying around, 6 psi off of turbo. Bov seems to be working properly. I havent checked if it was venting at idle.
Old Sep 12, 2006 | 03:47 AM
Chief Brody's Avatar
Doing a boost leak test is a good idea. You can get a tester for around $30. Then you can check every coupling.
user 11122324
42
Jul 18, 2022 03:35 PM
BkGreen97
Apr 2, 2016 05:47 AM
Unclejunebug
Apr 2, 2016 05:42 AM
