Where can i find the chrome or aluminum grille OEM replacemnt.
does anyone know where to find cheaper chrome or aluminum grille it has to be OEM replacement i dont wanna go thru cutting the grille and/or other modifications. i am looking for something that i can directly replace with stock grille. i saw one which is $160. whats the diffrence between Main Grille Insert and Grille Insert For Valance BTW its for 2k1 se. any advice will be appreciated.
what you guys says about the following ones are these the right replacement which one would fit my car without any modifications or cutting procedure>>>>>>>>>>>>>>>>
Main Grille Insert, OEM Replacement, Brushed Aluminum
Main Grille Insert, OEM Replacement, Chrome
Grille Insert For Valance, OEM Replacement, Chrome
and does anyone have (write up details) on replacement of stock grille cuz i realy dont know how to remove the stock grille. do i need a small screwdriver?
The Street Scenes grille is your best option. SS recommends cutting but a number of ppl we able to mount the SS grille over the existing grille. Kpazzo has a write up on his page. http://www.cardomain.com/ride/259701/1
Originally Posted by OC guy
thanks alot. buy do i have to buy valance grille along with main grille? or just buy the main grille and put it on top of the stock grille? dont i have to remove the stock grille in order to fit the aftermarket SS grille?
You don't have to get it if you don't want it. Some guys get only the valence grille. The stock grille is apart of the bumper. There is a piece that outlines the grille which you will have to remove. Take a look at Kpazzo's cardomain page and pics from my site. You can see the ss grille mounted over the stock grille.
You may one of those short stubby screw drivers to get to that fourth screw. As for the stock grille, you will need to cut it out. The bumper will probably need to be removed. Per the pic on ebay, it's apart of the bumper.
http://cgi.ebay.com/ebaymotors/00-01...QQcmdZViewItem
Originally Posted by doublea
I've posted a thread about it a year or two ago. Here is some pics of the result. I've re done the job since that first installation and it look much better now.
I dont recall where I bought the grill but it is made by Street Scene, it didn't came chromed I had it done locally to place that have been doing show chrome for 30 years. It cost me 200$ CDN to have both grill triple chrome process. The Nissan grill cant be remove on a 2k - 2k1 you have to cut it. To tie the lower part of the grill I use a drill and made small perforation in the lower inside part of the bumper and zip tie it. Ok first you have to remove the grill contour, there is few screw to remove I cant remember exactly the number or where they are located. It's a no brainer and to my knowledge there is only one way to install it the way I did it, you need to cut the grill unless you have a 2k2 then I believe the grill is removable.
You have to be carefull to not break the Nissan grill contour, I think there is 4 screw to remove. In order to remove the inside screw you need to use a small screw driver and remove it from the inside ( between the radiator and the grill ) get ready to scratch your hand or finger that's the price to pay to get something exclusive.
MR2 T'd
Jul 9, 2021 05:06 AM
dvcamp
Sep 18, 2015 10:17 AM
