Sponsored by:
Sponsored by: CARiD
For those with 3.5s in 4th gen,please explain ur fuel setup/fuel pump regulator setup
Old Oct 3, 2006 | 04:25 PM
ThisMaxIsTight's Avatar
Im having a 3.5 put in a 4th gen which is just about complete ... but as some of you have seen, theres a video posted by tavarish in which the engine has some serious noises going on idle ... I dont think its getting the proper amount of oil and and fuel in the engine..Im just curious to what people are using as their fuel pump regulator and what your using for the fuel system to work properly and efficiently ? thanks
Old Oct 3, 2006 | 04:39 PM
MDeezy's Avatar
I think you mean fuel pressure regulator. Most got theirs from ebay.
T-off a line into the regulator
What is the car doing to make you think its starved for oil?
Old Oct 3, 2006 | 07:17 PM
GodFather's Avatar
Made in Taiwan
My fuel setup is exactly the same as the good ol'4th gen's. Return type still there. I've done the swap with pathfinder heads which allows me to keep the manifolds and fuel system. Still using sidefeed injectors. No fuel pump nor fuel regulator replacements, yet. Walbro will go in soon, though.
Car runs lean and powerful at partial throttle, it gets pig rich upon 40%+ throttle. About to adjust all that with EU.
Old Oct 3, 2006 | 07:54 PM
krismax's Avatar
Father of the 00 VI
i have no aftermarket regulater i have it set up the same as the 3.5 swap facts show
Old Oct 3, 2006 | 11:11 PM
SpeedCrazie's Avatar
So what do we do if we want / need to keep the return style fuel setup?
Old Oct 4, 2006 | 05:14 AM
scrhale's Avatar
Why would you want to keep the return style? Just convert it to returnless.
Old Oct 4, 2006 | 06:54 AM
GodFather's Avatar
Made in Taiwan
Use pathfinder heads, use 4th gen lower manifold, voila, you can keep everything 4th gen in terms of fuel setup.
Old Oct 4, 2006 | 10:17 AM
tavarish's Avatar
fwd gone rwd cr00
I would much rather use the 3.5 manifold, and how do the pathy heads flow in comparison to the 03 max heads?
Old Oct 4, 2006 | 10:18 AM
tavarish's Avatar
fwd gone rwd cr00
How would I do that? Just cap off the return line?
Old Oct 4, 2006 | 10:28 AM
I have my reasoning, and I too would like to retain the VQ35 Heads and IM. I guess if I wanted to do this then I would just keep it setup like the 4th gen setup?
JP
Old Oct 4, 2006 | 11:37 AM
Nismo3112's Avatar
Custom User Title
Here is a returnless system. With this returnless system, fuel STILL returns to the tank, just not via the fuel rail. This is a different type of setup that are in the 5.5 gens.
Courtesy of Biggs_02 for the pic.
With that said, I had a normal return setup on mine, runs fine with no problems.
Old Oct 4, 2006 | 11:46 AM
tavarish's Avatar
fwd gone rwd cr00
thats how i'm running as well.
Old Oct 4, 2006 | 11:56 AM
When you say normal are you reffering to the orginal 4th gen fuel setup?
Old Oct 4, 2006 | 11:59 AM
Nismo3112's Avatar
Custom User Title
Yeah,
My setup was DE-K injectors, 3.5 rail, DE-K FPR on the end of the rail, and the SX7R fuel rail fitting on the other side of the rail.
Old Oct 4, 2006 | 12:23 PM
SPiG's Avatar
SomePsychoGuy
*is where it leaves the tank
stock 4th gen, return:
pump >* filter > rail > FPR> return > tank
stock VQ35, returnless:
pump > fitler > FPR V>* rail
return within tank
Semi returnless/hybrid:
pump >* filter > FPR V> rail
return > tank
The semi returnless is the best option IMO since it allows for rising rate pressure (good for boosting, easy access to the filter, and cooler temps of returnless.
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
00MAXI
Sep 2, 2015 10:23 AM
homewrecker
Aug 24, 2015 08:56 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
