Keep blowing a fuse.Need help!
I have a 01 SE MAX.Never had any problems with it.Last month my factory alarm stop working along with some of the interior lights.Check the fuses and found that one(10 Amp) fuse was blown.No problem, went to PepBoys and pick up a new fuse.All was fine.The next day same thing happen.The same fuse went out.Now a month later I've change the fuse many times and only last at most 2 days.I don't know what to do.I have not changed any thing on the car.Why after 5 years the car keeps blowing the same fuse?Maybe ground or short somewere.But I don't know were to look.Any help would be appreciated.
Originally Posted by bugbite77
what fuse is it exactly? the name should be on the fuse box cover. you should come talk a lil over at NYCMaximas.org, someone local (i live on long island) might be able to stop bye and help.
bugbite77 Do you have the same name on NYCMaximas.org?Where are you on LI?
Originally Posted by AKANeedles
I will look at it tonight and tell you.
Originally Posted by PAREDLINE
I'm in Roslyn Heights. Not for long though. Chances are you have a short. Once you figure out what fuse it is I'll see if I can email you a wiring diagram.
tarun900
19
Dec 20, 2021 06:57 PM
