Bad gas mileage on 03 maxima
I went out for a long drive yesteday, about 140 miles and had the cruise control on at 68mph the whole trip and I still managed to use up nearly 1/2 of a tank of gas. Something does not seem right. Right now I have just hit 50,000 miles. Just cleaned my air filter about 3k miles ago, changed the engine oil last month with sysnthtic 5w30 and tires are inflated to spec. What are some things I need to change/ replace at 50k mles to improve my gas mileage?
I am no expert but i have a 03 GLE and have the same problem. I was told my friend that the reason for the bad gas mileage was the idle air valve was not functioning properly not necessarily the spark plugs or type of gas (although those may have something to do with it).
it could be a whole number of things. and honestly for half a tank getting around 160 miles isn't too bad. are you automatic or manual? I do stop and go driving around my town and usually end up getting 250-300 miles for the entire tank; which is good for a 6 cylinder. My old 4 cylinder altima would get around 250-300 on a tank of gas but when I took that on to the highway for long trips I got around 420 miles on a full tank. Make sure your cars alignment is also good
Originally Posted by NmexMAX
Everything stated refer to this---> depends on the size of the tank
As to the original post, like someone mentioned already, there is a plethora of suspects involved with a change in gas mileage. Most of the common ones were already mentioned, but there's really nothing else you can do but guess and check...I would just do the routine maintenence and see what happens.
I get roughly 22 mpg in mixed driving just to make sure, when you're using your cruise control you're not using it on hilly/windy roads right? In those situations using cc will actually worsen mileage because the computer is constantly trying to maintain that constant speed.
granny?
Originally Posted by BLK2BLU
Miles and gallons are constant around the world
Canadians use it, as well as Europe.
I live in a hilly area, use my cruise control a lot and get over 200 miles per 1/2 a tank.
I changed my plugs at 100k and they weren't that bad but, every car is different. I would at least check the front ones. o2 sensors? MAF?
So what do you do.. Climb the hill like a
granny?
You sure about that? What about liters and kilometers?
granny?You sure about that? What about liters and kilometers?
A mile is a mile no matter where you go. Same with a gallon. We use liters here and run the 5K...10K....etc. I'm not talking about what others use...I'm saying that a gallon is a gallon. Not all tanks are the same size.
Why do ppl refer to their gas mileage in terms of miles/tank and not miles/gallon? Lets all use a standard. Miles and gallons are constant around the world....so lets use that.
Originally Posted by Decoy036SPD
the difference between my altima gas tank and the maximas was I think only 2 gallons.
sounds a bit off.... When i cruise around town i can keep 320-350 to a tank. Only thing i did recently was plugs, and that was just because i felt a bit of a power loss, mileage was still good. I do have a pretty light foot.. maybe thats the problem
Were all the variables the same? The weather is nicer now, were you cruising with the windows down? Extra junk in the trunk? Was it windy that day? Were you out in the open vs tailing someone?
Then there is the whole winter gas theory. It is about time for those arguments.
In this forum miles per tank is just out of ease. Ignoring the obvious difference between the 5 vs 5.5 we all have the same engine, tank size, etc. You are correct though it isn't as accurate, but doesn't require any effort either. There will be a difference in the person who tops a tank vs stops for the click. I think a lot of people get caught up in the absolute numbers vs whether they are close to the reported average between members.
1 US gallon = 3.785 liters = 0.8237 imperial gallons
We mostly use L/100km in Canada but still often refer to miles per gallon (especially older folks). When we do miles / gallon, we do miles per IMPERIAL gallon which is obviously different than miles / US gallon.
I do, however, agree with you that it makes more sense to talk miles per gallon than miles per tank.
Originally Posted by BigFly_2K2SE
Untrue.
I stand corrected
mine seems like it gets ****ty gas milage too. Theres gotta be something wrong with it. Im at 56,000 miles and probably in need of a minor tune-up. I filled up the other day with over 40 buks in gas and its half way gone. I dont remember even really going anywhere. The dash always stays stuck at 22.5 or 22.7mpg so I know thats bull****. I might change the plugs but even if there bad I dont think its gonna make that much of a difference in mileage. If a sensor was bad would the car throw codes??
Mine is bad too.
Suspecting its the o2 sensor.
Filled up last weekend, and do almost all city driving (12 miles per day, city driving) and i'm at 1/4 tank left (towards the empty side) and only did 122 miles!
Something is definatly wrong, and I think I'll start by checking my plugs.
Originally Posted by four
Mine is bad too.
I'm *****ing and griping cause I'm at 268 and at a quarter tank. More highway than city, but the highway is Ups and Downs and LOTS of curves. So its not a good measure.
When I bought the car 4 months ago. I was getting 21-22mpg for the first three/four tanks. The last 2 - 3 tanks have been late teens. Same driving.
Something changed. I doubt plugs, not at 53k. Plus our plugs are suppose to be good for 100k. o2 maybe. But no codes...
I hate this. Getting almost same mileage as my old Truck in a car with a smaller engine and lightweight. The pathfinder use to give me 14-15mpg religiously. Max is seeming to gonna be 18-19 regiously. I expected low 20's. Not high teens.
Originally Posted by rmd0311
122 miles driven and you are already at a quarter tank... Damn...
maxima gas milage sucks, ive been getting 20 mpg and i accelerate slow as hell, hwy/city mixed. if i drive any faster my milage gets worse. nissan isnt great at gas milage, acura TLs get around 29 mpg on the highway.
Mine doesn't suck. I can get 25 mpg even doing a few WOT bursts on the highway. I have gone as high as 27 mpg.
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
Jcof88
Aug 3, 2015 10:43 PM
