ContiExtremeContact - 235/40/18: $125
Old Oct 23, 2006 | 12:00 PM
djfrestyl's Avatar
Suspension Yoda
TireRack has many of their Continental tires on special pricing. I just picked up 4 ContiExtremeContact in 235/40/18 for $125. They're normally $140+
Just FYI
Old Oct 23, 2006 | 04:10 PM
MaxBlack97's Avatar
I have heard bad things about those, did ur kumhos give up on u? I thinking about taking the cheap way out and going with nexens myself
Old Oct 23, 2006 | 04:30 PM
upstatemax's Avatar
What have you heard bad about them? The sidewall is a bit soft, but running higher pressures helps big time... Over a GREAT tire, for the money, they are really hard to beat.
Old Oct 23, 2006 | 04:51 PM
Kevlo911's Avatar
Kevlo for President
They are a great tire, I would have got them if they were that price when I got my tires.
Old Oct 23, 2006 | 05:07 PM
djfrestyl's Avatar
Suspension Yoda
They didn't give up. They just got worn down...that's what tires do
Old Oct 24, 2006 | 07:41 AM
MaxBlack97's Avatar
quick question do these guys give warranties on their products?
ex. If a tire blows can you send it back for a free replacement cuz up here in NY potholes get serious, and they eat low profiles daily
Old Oct 24, 2006 | 01:16 PM
djfrestyl's Avatar
Suspension Yoda
Only way to find out is to call.
Old Oct 24, 2006 | 02:41 PM
MaxBlack97's Avatar
cool thanks
Old Oct 26, 2006 | 10:21 PM
l3ftonm3's Avatar
good deal, i misread
Old Oct 27, 2006 | 07:28 AM
MaxBlack97's Avatar
they r 123.60 on tireeasy.com
Old Oct 28, 2006 | 10:00 AM
djfrestyl's Avatar
Suspension Yoda
Tireeasy.com's shipping is also $4 extra per tire. You do the math.....
But I do appreciate you finding that, I'll call TireRack to see if they have a price guarantee
Old Oct 28, 2006 | 08:55 PM
MaxBlack97's Avatar
yea u can prob get sum credit or something, who ever had these 4 the long time, how do they compare against the Toyo Proxes?
Old Oct 31, 2006 | 07:06 AM
d00df00d's Avatar
Old enuf to pick his own gears
Which Toyo Proxes? There are a lot of them...
Old Oct 31, 2006 | 09:14 AM
MaxBlack97's Avatar
Toyo Proxe 4s
Old Oct 31, 2006 | 10:30 AM
d00df00d's Avatar
The ContiExtremeContacts will have better snow traction for sure.
From what I can gather, in a 50-series or higher size, the Contis will also have a firmer sidewall; in a 45-series or lower size, the Toyos will have a firmer sidewall.
The Contis are rated for higher treadwear.
The Toyos have a better track record for quality (durability, how well they maintain balance, etc.).
Dry/wet performance is a tough call. It seems that no one has done a direct comparison between these two tires, so it's hard to tell which one will be better in this department. My instinct is that the Proxes 4s will have the edge since they have bigger tread blocks and use a similar tread compound to that in the Proxes T1-S.
Old Oct 31, 2006 | 12:53 PM
MaxBlack97's Avatar
thanks 4 the info toyo ftmfw
Old Nov 1, 2006 | 10:03 AM
Chunger's Avatar
My other car is a Hybrid
These tires are quiet and comfortable (and good in rain and supposedly snow)... not as much grip as my old Kuhmo 712... but now i'm running them at about 45psi so that helps.
Old Nov 1, 2006 | 05:57 PM
limsandy's Avatar
Are you ****ing serious? What size are you running? That's about the maximum pressure you can put into the tires.
Old Nov 3, 2006 | 11:18 AM
Chunger's Avatar
245/40/18
The long time owner of the tire shop i usually buy from runs in the 50s on his pickup.. LOL. I commented on how "soft" the tires were and he suggested it. I've been running on that pressure for like 5 months now.
Old Nov 3, 2006 | 11:48 AM
d00df00d's Avatar
http://www.tirerack.com/tires/Spec.j...e1=yes&place=2
Maximum rated pressure for that tire in that size is 44 psi...
50 psi is not unusual for a truck tire. Many of them will run around 80 psi. But they're made for that. Car tires aren't..
Old Nov 6, 2006 | 05:44 PM
Chunger's Avatar
You can sue the guy for me when i'm dead...
Old Nov 6, 2006 | 06:39 PM
d00df00d's Avatar
Roger that.
Do I get dibs on your mods?
Old Nov 7, 2006 | 12:47 AM
limsandy's Avatar
I know this is not OT and all, but...... can I have dibs on your gf/wife, if you have any?
Old Nov 7, 2006 | 10:53 AM
Chunger's Avatar
I'll grease up my Chihuahua for you...
My car will probably be total'd... never leave anything for the vultures...
Old Nov 7, 2006 | 11:25 AM
d00df00d's Avatar
Fine. I see how it is.
Old Nov 21, 2006 | 06:36 PM
djfrestyl's Avatar
Suspension Yoda
Bumping this. I've had the tires on for about a week. Great traction in wet or dry, warm or cold. (Better wet traction than my previous ASX's)
I'm running 235 on a 7.5 rim. There is no excessive "bubbling" outwards of the sidewall but I do notice the sidewall is a bit soft, as if the tire is rolling slightly on the rim when I make a quick turn or lane change. It's noticeable more than my previous Kumho ASX's, which seemed to have a more "vertical" sidewall, even though the width and profile were the same.
Just my $0.02.
Greenmaxspeed
Aug 31, 2015 09:06 PM
TurboA32
Aug 27, 2015 08:44 AM
98nismomax
Aug 26, 2015 03:03 PM
sonic7
Aug 20, 2015 12:23 PM
