squeak going over curbs slowly?
i have a slight squeak when i go over curbs like backing out of my driveway, my car is dropped so i go over them slowly, this just started happening. i have tokico struts and progress drop springs only 6 months old on the struts and springs so i highly doubt its either of those. what if anything can i look at under the car to see where this might be coming from? any help is appreciated im totally lost on this one.
Most likely its from the stopper bolts that contact the control arm at full lock. When the suspension compresses on your lowered ride, the tip of that bolt is coming into contact with the control arm.
Just jack up your car, use a 17mm open ended wrench and take them off to see if the noise goes away. They are threaded into the bottom part of your hub.
Yep, larrio said the same thing that i was going to point out. As this happens to me to cause there is suppose to be a plastic cap thats suppose to be on there but it usually falls off due to wear and tear. I have the part number if you want it.
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
