Cold Start Idle Surge
The Max's idle has been surging during cold starts. It'll crank up fine and do the fast idle for about 1-2 secs then go down to ~500rpms once or twice (without fail) and then continues to fast idle. Everything's fine after those surges. No CELs.
I recently replaced the PCV valve with an OE one all hoses I removed are connected again; nothing's cracked I even replaced the PCV valve again with another one same deal.
Any ideas? I won't have time until tomorrow to check it over again. Thanks guys.
check your fuel pressure, perhaps the pressure regulator is shot. i too have the same problem and i actually talked to a guy i work with and he said he had a similar problem, once he replaced the regulator it ran like a top. i yet need to check the fuel pressure, but it's something to check. once i get around to it, if soon, i'll let you know what i find.
My 99' use to idle at 2000 rpms on a cold start and then would fall to 1500 rpms for a minute then slowly go down to a normal 600 rpms. I did not like the high rpm start so I cleaned the TB, IACV and changed the fuel filter. Now my max is cold starting at 2100 rpms and then falls back down slowly. The rpms also rise to around 2000 rpms when I disengage the clutch to shift gears while driving. It stops doing this when warmed up. Any suggestions on what is going on? The TB and IACV were not very dirty and the car only has 65k on it.
There is nothing wrong with your car.
Originally Posted by njmaxseltd
Thats perfectly normal cold idle operation.
I'll order the FPR and report back.
By the way, anyone experiencing worse fuel economy?
Maybe going to 2k on start up, but why does my car rev up when pushing in the clutch? Like I said, this just started happening after I cleaned the TB and IACV.
TPS unplugged, enigne completely warmed up, adjust the default idle speed on the throttle body to about 600 RPM's. Turn off the engine and reconnect the TPS. Start the engine and make sure the idle speed is within specs. If it's not, adjust the IAVC bypass to bring the idle speed back to spec.
It's normal for the idle to hold up slightly during a shift, the manual ECU is programmed to do that. But your 2K RPM's is a bit high, perhaps that adjustment will help.
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
ballerchris510
Sep 10, 2015 09:35 PM
