chewing through rear brakes? LOWERED? YEAH
Old Oct 30, 2006 | 09:50 AM
kamski's Avatar
.org extraordinaire
So I just read in the brakes section that since our cars are lowered the EBD control module will send more braking power to the rear brakes, this is kind of pissing me off cause I'm replacing my rear pads every 10K-15K.
Anyone else have this issue? Anyone (ehm nissan techs) know how to disable the EBD module on lowered cars or adjust them for compensation on lowered vehicles?
Thanks Fellas,
Kamski
Old Oct 30, 2006 | 10:04 AM
!PrjctMax!'s Avatar
If we're just lowered with stock brake set-up should we worry about this issue as well?
dan
Old Oct 30, 2006 | 11:53 AM
xoomer.com's Avatar
I Donate! Why Don't You?
wierd, I gotta check my rear pads.
Old Oct 30, 2006 | 01:37 PM
!PrjctMax!'s Avatar
Since we're on this subject. Would getting front 4POT Wilwoods and rear 2POT Wilwoods also effect the bias like you're saying?
Old Oct 30, 2006 | 05:05 PM
xoomer.com's Avatar
Where did you see 2 pot wilwoods for the rear? Does Brian offer those?
Old Oct 30, 2006 | 05:48 PM
!PrjctMax!'s Avatar
sheet, I guess he doesn't then. lol I just assumed that he might. So would 4 pot in front and rear just mess everything up?
Old Oct 30, 2006 | 09:41 PM
kamski's Avatar
.org extraordinaire
WHOOOOA NELLY, he does have them for the 350Z and G35 and since I have seen an ALTIMA 3.5SE with the BREMBO kit from the 350Z its pretty safe to assume the rear Willwood kit from him will fit our cars as well.
He hasnt released anything yet officially because there is no market for it, but ask him about the G35/350Z kit and you should be set. The rears use Dynalite Single Dual side caliper (Tough name for a 2 pot caliper ).
Anywhoo, even before I got my BBK I was chewing through rear pads pretty fast. Now that I have more stopping power I'm eating them up even faster.
I have a feeling that if i put on the stock rear springs all will be good again, yet I dont want to ruin the way my ride is now and the Cattman springs provide me with just enough (FUN FACTOR). So I'm looking into an alternative to fix my rear bias issue. Maybe a bias adapter from willwood or something....
Kam
Old Nov 1, 2006 | 09:06 AM
ardika's Avatar
Kam, are you saying that the stock gold brembos from 350z could actually be installed in the Altima w/o significant modification?
Where did you see this?
Old Nov 10, 2006 | 10:32 AM
kamski's Avatar
.org extraordinaire
At Nissanclub.com/forums
Some dude installed them on his black Altima, since the same part fit our car........... god speed!
Kam
Old Nov 10, 2006 | 05:53 PM
AllBlackMax's Avatar
aka The Doom Ship
I don't think being lowered is your problem. I've been lowered for about a year now and have no rear brake problems. It's my front brakes that are toast. My Brembo rotors just came in today and my Hawk HPS pads should be here by Monday.
My front passenger side brakes are making an awful clunking/grinding noise when I drive now. Hope the caliper ain't damaged.
Old Nov 11, 2006 | 02:57 PM
MisterSparkle's Avatar
it might be cause your running on slotted rotors...i've read that slotted rotor, while giving better stopping power chew through brake pads lik a ham slicer...lolxz
Old Nov 11, 2006 | 03:22 PM
!PrjctMax!'s Avatar
NOTHING gives you better stopping power other than blanks. Slotted/drilled only provide better stopping power while under hard braking constantly. Just think about it, blank=most surface area, slotted=best ventilation and drilled=worse surface area but decent ventilation but more prone to cracking.
Dan
Old Nov 11, 2006 | 03:34 PM
xoomer.com's Avatar
Dan
Sounds right!. Under normal driving condition blanks will give you most traction area, thus providing better stopping power. For track use, the vents will be more usefull as they will not only vent (cool) your brake system faster but also let the pad gasses escape through these slots/holes. Please note however that with modern brake pads, the gas problem has been nearly eliminated.
Just my $0.02
BTW. I don't know if its me but every time I see a MB AMG with these huge calipers and drilled rotors the wear on the rotors is extremely uneven making the surface look like
Well thats the best way I can quickly show it.
Old Nov 12, 2006 | 05:50 AM
!PrjctMax!'s Avatar
those 2 things happen at once! jk
I've never noticed this myself, but I have seen many AMG's that have the huge 6POT BBK's and it makes me
dan
Old Nov 12, 2006 | 06:14 PM
xoomer.com's Avatar
Duh,
Thanks for letting me know Dan. All I was saying is that the gasses are no longer a problem with the modern pads. Its the proper cooling that is always a problem and thats what these holes are for.
Old Nov 12, 2006 | 07:00 PM
!PrjctMax!'s Avatar
Duh,
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
