rear bottoming out
rear bottoming out
I have a 99 max with ground control coilovers and tokico illuminas. I am using the stock 16's. My problem is that I keep bottoming out the rear even with noone in the backseat. I dont have a big subbox in the trunk. I kept wearing out the struts. I replace them and a year later they are worn out. My friend has the same setup and uses agx's instead on 18's and he has the car slammed and he doesnt bottom out. So I replaced the illuminas and bought some agx's to use. The ride is better with the agx's but I still bottom out. It doesnt bottom out as easy but then again these struts are new. I called gc and they swear that their springs cant and wont ever sag.
I need help, I am about to just go back to the stock springs. I can bottom out the rear with just a lane difference like when they pave just one lane and the other lane is like a 2 inch drop. If I go over it like at a T doing 5-10mph at an a intersection it will bottom out! I dont have the coilovers all the way down. The rear collar is all the way up.
Please help
Please help
I still bottom out with brand new agx's too.
Heres a pic of the left rear strut b4 I replaced it with agx. As you can see I dont have the collar lowered a lot. I did cut the bump stop per ground controls advice.
I would NOT NOT NOT cut the bumpstops for any suspension setup ever again, after my experience. I too bottomed out all the time, and really harshly, after I cut my bumpstops (front only). I never cut the rears because it didn't look like a good idea with the rear design. See my comments at the end of this thread. Part of my problem is that my springs (H-Techs) are just too soft for the amount of drop they give, but in your case I bet that replacing the bumpstop/dustboot unit with a new OEM replacement would help you a lot. Even if you were still bottoming out for some other reason, your ride would be a lot more comfortable because you'd have enough rubber to slow down the strut before it crashes into the bottom. Bumpstops are your friend!
http://forums.maxima.org/showthread.php?t=291334&page=4
lowpost99
Oct 26, 2025 06:53 PM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
