This Sucks!!! Car drifts Left
Ok this is really starting to **** me off... .had 3 alignments done and the car still drifts to the left...
for the record
Brand new continental extreme contacts 1 month old.. (dealer inspecte ok)
Brand new nissan inner and outer tie rods
Brand new nissan wheel bearings..
Brand new axles, ball joints, sway bar links and control arm bushings
There is no play in any components... but the car still drifts a lot to the left... now i notice it drift more when i accelerate!! the brakes are new as well and they dont drag....
Somebody please shed some light one me... this really sucks....
for the record
Do you mean its pulling to the left? Sounds like who ever is doing your alignments isnt centering your stearing wheel properly. Everytime I align my car it always pulls either to the left or right because there is so much play in my stearing rack that I cant get the wheel centered.
Originally Posted by Geo T
Hey Sebastian,
Have you tried bleeding your front brakes
I thought when you brake it drifts to the left, you may want to check your alignment again.
Something on the install on all your parts is not right!
Who did the install/alignment?
no the tires are on correctly... im gonna use my friends wheels and see waht happens...
the steering rack bushings look good... but if anybody can shine some light here....
like 2 months ago i was playing around with the bushings on the steering rack.. now i moved the rack a little to the passanger side..
after that the car started to pull left... i took it in and they told me to replace the inner tie rods outer and the wheel bearing onthe drivers side..
took it back and they did the alignment and it pulled.. i took back in and they did the alignment again... but heres my question.. if the rack did move to the right and they did the alignment with the rack moved when i drive the rack is gonna try to even itself out and pull left?
its not torque steer.. im talking about normal driving here.. this is the most frustrating thing ever.. i accelerate normal and it pulls to the left... its nothing draggin cuz i checked the front brakes and even replaced the driverside caliper... this sucks
have you ever hit any curbs or hit any major pot holes or anything major that you can remember, because it might be one of your control arms, my last car was a subaru legacy and i hit a curb real hard in the winter and bent one of my rear right control arm causing it to drift left, maybe thats whats wrong with it, sounds like it to me.
It looks like you just replaced the control arm bushings & components, not the entire arm! So, that may be it. Also, like I stated in my last post, try rotating your tires.
the few people that i have talked to (my shop teacher who is getting ready to retire and has a lot of expirience) say that you should really sit in your car when they align it or it will throw it off a little? At the dealership i work at
they won't even let any customers in the shop, much less sit in their cars while they work on them.
Dude - I'm going thru the same exact problem, and it's been driving me totally off my rocker!
I just recently got new Shocks/Springs, and since then it's been doing it.
I have a couple of people trying to work on it to figure it out, so if I hear anything concrete, I'll let you know ... and if you come up w/ something, please let me know.
i have something close to the same problem but mines is when im on the highway and slightly turning and i hit a pot hole or bump the car jerks me to the size im turning what could that be if anyone knows or had the same things happen?
Lakersallday24
Jun 16, 2019 01:35 AM
trasmadean
Feb 1, 2017 08:20 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MikesChevelle
Aug 6, 2015 11:36 AM
