Ladzio's Guide on Assembling LED Tail Kits
DISCLAIMER: Purpose of this thread is to help several orgers put together LED kits that they have purchased from me. However, I believe others will benefit greatly from the information presented here.
I NO LONGER HAVE ANY KITS NOR DO I MAKE ANY. THIS IS NOT INTENDED TO BE A HOW-TO THREAD, THERE ARE TONS OF WAYS TO ACCOMPLISH A PROJECT LIKE THIS.
bohead, juani, MaximaEvolution, MaXamillion: you guys have received already Word file from me that shows board legend and gives general instructions on how to solder components on the boards. I will repost those here a little later.
Google for anything youd like to know more about. There is tons of info out there!
Here is basic info: http://www.iguanalabs.com/basicdef.htm
Now, how things work in general:
LED (Light Emitting Diode): Two important variables to pay attention to:
1. Volts - how much power it needs to light up - RED 2.5V / WHITE (some of you got them) 3.4V
2. Amps - how much current they draw - RED 70mA (milliAmps) OR 0.07A (1A=1000mA) / WHITE 20mA
(Think the value represented in volts as the diameter of the water pipe and the value of Amps as the speed with which water flows in it).
Resistors - are used to "resist the power flow", thus they kick down how much Volts are running in a circuit.
Depending on how many volts is supplied into the circuit and how many volts is "eaten up" by the components (LEDs in our case), we will need to use resistors of different capacities to balance things out. Resistance is measured in "Ohm" units. E.g. 330Ohms. Also resistors cut the Volts down not by exact value but depending on circumstances (e.g. outside temperature), by a proximate value. In other words, their efficiency to cut volts down is understood as tolerance. E.g. resistor with a tolerance of 5% will drop the volts down to a certain number give-or-take 5% of that number.
All resistors are marked by color bands indicating its rating and tolerance. Certainly the smaller the tolerance the better.
Link to decode resistor color bands: http://samengstrom.com/nxl/3660/4_ba...e_page.en.html
Next great resource I used in creating circuits: Board Array Wizard: http://led.linear1.org/led.wiz
In my boards design I used parallel and serial chains. You can see there are 4 or 3 LEDs followed by resistor in a chain. now all those independant chains are connected to separately running ground and power.
Red lines are copper strings that run on top of the board, Green are on the bottom.
This board has only chains composed of 4 LEDs in each chain, and if we supply 12V to each chain, then we have 4 LEDs (4 x 2.5V) consuming 10V, thus we need to kill extra 2V to balance things out (otherwise extra voltage will damage the LEDs), so we use resistor for that. How do I know I need 33Ohm resistor? - Wizard told me! Thus with the help of the wizard you can figure what kind of chains you can run and what resistors to use. All you need to know is the specs of your LEDs, how many LEDs you use and how many Volts you supply to the board that houses the components.
A little more crowded board now, but same logic.
This info is so far enough for you to solder LEDs and resistors on the boards, so now is time for brainwashing and "please-do-not-screw-up" pray!
Soldering Components on the Perfoboard – DO NOT START UNTIL YOU READ AND RE-READ THIS SECTION ENTIRELY! THESE INSTRUCTIONS ARE TO BE USED IN COMBINATION OF YOUR KNOWLEDGE AND COMMON SENSE. I AM NOT RESPONSIBLE IF YOU SCREW UP!
Perfoboard contains only 2 types of components: LEDs and resistors. In this set up, serial and parallel wiring is employed. Chains of LEDs in groups of 4 or 3 etc. are followed by resistor and then connected in parallel to Positive and Ground. Before you start soldering:
A.Keep in mind that resistors are not dependent on polarity, meaning it does not matter what leg goes into what hole. LEDs on the other hand depend on polarity, meaning positive legs have to go into positive holes (ROUND COPPER HOLE) and negative legs have to go into negative holes (SQUARE COPPER HOLE).
B.Components can and will be damaged by excessive heat. Never apply soldering iron for more than 2 seconds. If solder did not melt and affix properly, move on to the next component, and continue with the previous one after it cools down. Otherwise LED may prematurely go out.
First identify groups of LED chains in serial in order to determine the correct resistor that would complete the chain, e.i. count number of LEDs in a chain, plus consult legend
ATTENTION!!! Colors Legend:
RED – copper string on top of the board
GREEN – copper string on the bottom of the board
YELLOW – outline of the board and of the components
FOR EXAMPLE (See First Picture): In the left lower corner it is vividly seen how positive string goes to the positive leg of LED, which are then connected in series forming group of 4, then going from negative leg of last LED to the resistor and then to Negative string. Group of 4 to the right top corner is a little less obvious. Note how group of 3 LEDs starts at the top and then copper string in green goes to the forth LED located on the bottom right corner.
HOW DO I TELL WHICH LEGG OF LED IS POSITIVE OR NEGATIVE:
Notice how top left corner of LED is cut at an angle, while 3 others are square. Top 2 legs are Negative. Bottom 2 legs are Positive. LEARN IT BY HEART! Note how two legs of same polarity are on one side of diode and other two legs on the other.
BEFORE YOU SOLDER RESISTORS READ THIS:
This should keep you busy. Nest week I will cover PWM and Voltage regulation. BUT!!! You will ask why do I have in my legend resistors you gotta use if we supply 12V and ones if we supply 10V, where does 10V comes from?
We get 10V if we regulate our voltage, as a result 2V are wasted in heat.
Why do I care about regulating voltage? Because car does not supply constant 12V all the time, unlike power supply in your desktop. It jumps sometimes up to 14V, but occasionally a voltage or current spike can be much higher than that and that can damage LEDs. Now, I had my first set of tails using cheap HongKong 5mm leds for 2 years and never anything burned out (except one led after 2 weeks, likely because I overheated it when soldering). So to use or not to use voltage regulators is your call.
BENEFITS: Protects from current and voltage spikes, thus long life for LEDs. All car manufacturers have these on their LED tails or somewhere in the circuit.
DRAWBACK: Heat management and more wiring. The regulators I created are heating very much, despite my calculations that Amps were low and heatsinks had double capacity. Possible solutions: A. Use ventilator to create airflow and facilitate cooling. B. Affix regulators on car body itself so it would serve as one large heatsink. C. Use other regulators of bigger capacity so that heat would not be an issue.
Thus, if you decide to use regulator, you will need to have such that drops voltage no more than up untill 10Volts and might need to rerun wizard to see if resitors are all in order.
MaXamillion - your boards are done to get no more than 10V, so you must use regulator or something that will kick Volts down from 12V to 10V.
SOME MORE RESOURCES ON THE NET:
Piranha LEDs (chepaer but less quality too: http://www.besthongkong.com/index.ph...67fa1e34493878
Various Electronic Parts Distributor:
http://www.futureelectronics.com/
http://mouser.com/
From here I got most of my parts - CHEAP: http://www.digikey.com/
Another excellent distributor: http://www.jameco.com/
PWM Vendor:
http://www.ledcar.com/
http://www.quickar.com/tkit.php?session=O66wTsFL
http://www.web-tronics.com/dcmotspeedco.html
http://velleman.hobbytron.com/vseries.html
PWM in detail:
http://www.cpemma.co.uk/555pwm.html
http://home.cogeco.ca/~rpaisley4/LM555.html#2
Voltage Regulators in detail:
http://ourworld.compuserve.com/homep...den/page12.htm
LED Series Resistance Calculator
http://ourworld.compuserve.com/homep...Bowden/led.htm
All you wanna know about physics:
http://hyperphysics.phy-astr.gsu.edu/HBASE/hframe.html
http://mouser.com/
PWM Vendor:
PWM in detail:
WHERE DO I GET THE PCB? (Perforboards on which components are placed)
I used the software from http://www.expresspcb.com/
Download the software, familiarize yourself how it works and design a board to your preference. Then you can place manufacturing request to the factory right through that software.
Money Saving Tip: Once you designed all individual pieces, place them all on one single PCB sheet. Then once PCB comes just cut into pieces. There is also a tool to calculate cost of boards before you submit them for manufacturing.
No. Heating tails in the oven does not affect wiring or components. It is just not hot enough and not long enough.
About resistors, you will need certain kind depending on how may LEDs you have in one chain on the board and how many volts you are supplying to the board.
Read info regarding regulators above. As I said they get hot, but I did not experiment enough to see if that would create any problems - according to my calculations it should not and maybe that heat is all normal. But again my feeling is to get heatsinks of better capacity.
I am going to look at files I have on my desktop and will give you all calculations I have.
Exactly. Now let's assume you use regulators and supply only 10V. Then in the chain of 4 LEDs you would not need a resistor!, but just for safety and because Wizard says so, you use tiny 1Ohm resistor (and 39Ohm where you have 3 leds in chain). So depending on whether you gonna use regulators or not, part of resistors you will not be needing. You got so many resistors because I sent you 2 different sets dependingon whether you supply 10V or 12V.
Originally Posted by max2nveee
hey man, i was wondering if i put the LED tails in the oven will i ruin the LEDs or wiring.
Originally Posted by MaximaEvolution
Do we really need all these resistors? And what does the flasher, transistors, heatsinks, etc. get soldered to? Shouldnt they be on a board? Or is that was the little box is for, wire everythin and shove it in? Which I'm totally down for, just wanna check lol.
right, that part i completely understand- 2.5V per LED + 4 LED's = 10V then you need resistors to consume the extra 2V. I meant, the amount that you sent me lol. It just looks like a lot of resistors and so far I only see where to use the 33 ohm and 66 ohm.
The LM317 Voltage regulator I sent to you can handle 1.5Amps tops. I will later post a diagram where by soldering resistors of different values to different legs you "program" it to give out approximately 10V.
Now, as an example, I will calculate how many Amps inner parking/brakes board draws.
We have 6 chains (4 LEDs in each). Each LED is rated at 70mA. How many Amps does each chain draw --> 70mA (NOT the sum of all 4 LEDs - because they are connected parallel to the source voltage (and in series to each other), does not make too much sence but this is how a knowlegeble member from HIDPlanet.com told me to calculate, so remember it).
Thus, 6 x 70mA = 420mA. Since LM317 is rated at 1.5 MAX, you can safely run one more board from same regulator. Thus, knowing how much each set of LEDs drwas, you design the harness accordingly.
Here is another good resourse to "program" LM317.
http://www.muzique.com/schem/lm317.htm
I also have the diagram of the switch circuit employing transistor but cannot find at the moment.
Here is a diagram, scroll to page 5.
http://www.lotusenthusiasts.org/Newsletter/V5-10.pdf
You have the resistors of those values. I did some more research and see that I just might have used heatsinks that are not up to the challenge of LM's heat. Research http://www.digikey.com/ for beffier ones.
Now here is how I mounted them inside, but you are free to do it your way.
Originally Posted by QnzMax
Ok, I just tried wiring them and I wasn't successful. I am really stupid when it comes to wiring. How exactly do these things get wired. Do the 3 wires from the control box get wired to the harness that gets plugged into the tails?
If anyone has pictures that would help a crapload. If no pics, a step by step wiring guide would be great. Also I opened the control box and there was a red wire dissconected from the pheonix connector. Is it supposed to be dissconected?
Ok, does it matter which harness the 3 wires get tapped in to? The right or left tail light harness. I tapped into the drivers side harness. Black to Black, Red to Red/Green and White to Red/Blue
I will take pictures tomorrow. Also is that red wire supposed to be disconnected in the control box?
Also the harnes you have, short one run along the fore side of trunk - that is for outer tails. Long one run into the trunk lid, that is for inner tails.
ok I see where the regulators are mounted, and its starting to make more sense.... BUT (lol) ...
1 - What is the board in the center of the box for and do I need it?
2 - Why is there only 7 heatsinks, when there are 8 boards?
lookin at everythin again, I understand why you only used 7 heatsinks.. you must have wired two boards to one of them?
So essentially, all I would need is 4 regulators and wire two boards to each of them. But then, wouldnt that mean more heat out of each of them? Then again, If I had 8 individual heatsinks in there it would cumulatively be the same, correct?
That LED flasher replaces the stock one correct? Does it just drop right in or do I need to wire it in?
2. Inner brake boards draw 420mA each, so I wired them to one regulator. Outer brake boards draw 560mA each (8 chains X 70mA) and I also ran them to common regulator (560 + 560= 1120mA so regulator still can handle that). Then I ran inner turns from same regulator, outer turns from same regulator, inner reverse from same regulator and outer reverse from same regulator. In total 6 regulators!
3. In the 2nd PIC on top right "regulator looking thing" with a heatsink is actually a Transistor. What does it do? It switches the circuit to a stable ground (as opposed to interrupted one from PWM) when you hit brakes (see description obove on how PWM works).
4. About heatsinks, I think heaving better heatsinks will solve the heat problem, but placing all of them in a confined box might defeat the purpose - need some ventilation there, or could affix them just on outer walls of the box.
5. LED flasher simply replaces stock one.
so I need to purchase a PWM, correct?
Part # ML-804. It is rated at 20 WATTS max, so 20W/12V=1.6A
Now our brake boards draw 560 + 560 + 420 + 420 = 1960mA OR roughly 2A. So this PWM is not strong enough, thus you will need 2 to split the load or find something else. You can use the one I used, Valleman PWM, rated at 6A, but it is complex and overkill for this application (costs $20).
I noticed today that my left front directional hyper-blinks and the left tail directional doesnt flash at all. This is the tail light that i connected the control box to. Anyone know what it could be?
Would it be possible to Wire in 2 PWM's?
Say I were to wire both the left outer and inner brake boards to the same regulator (560mA + 420mA = 980mA) and then do the same with the right outer and inner tails. Then have individual PWM's for each.
possible? advantages? I like the fact that each regulator would be workin equally as hard (980mA) hahaha I'm **** like that.
ok I have all the LED's On the brake boards with all the resistors. So now that I have the resistors, I dont really need the regulators? Or should I put them on, with different resistor values on the legs?
I'm still confused on the wiring part of it but, one part at a time lol.
-Mike
-Mike
If not, then you use resistors according per file I e-mailed to have boards running off 12V.
If you do, then you use resistors to have them feed off 10V.
hey ladzio... I was lining up the boards to solder on the LED's for the turns & reverse signals and I have 2 questions:
1 - The white LED's are completely surrounded by the red ones, correct? These boards are the same as the ones in the pictures on page one of this thread?
2 - I think I have the orientation of the boards right, but for the right side boards, in order to match it to the left side, they need to be flipped over. Is that ok to solder the LEDs on the reverse side?
* I did a little research on the LM317 and found this:
http://www.electronics-lab.com/articles/LM317/
figured youd get some use out of it.
As to the boars, YES some boards will have to be flipped. VERY important not to mess up! That earlier picture shows how it needs to be. I'll post enlarged version later.
White LEDs go inside and reds are on the sides. Also I noted I have more red LEDs left than I thought. Maybe I cut someone short when counting. Let me know if you run out.
33ohm and 66 ohm is for 12 V... but wouldnt I still be able to run the regulators? I would just have to use different values on the legs of the regulator, to keep the voltage at ~12V.
Id rather use the regulators just to be safe, no?
I understand exactly what u mean.. but dont the resistors on the legs of the regulators determine its "program" So couldnt I change those values and "program" it to regulate an average of ~12 volts?
See the link I posted earlier about calculating resistor values to get 12V. Post your findings on HIDPLanet.com in their LED section and see what response you get. There are some very knowlegable members there.
How did you mount the boards inside the housing?
Originally Posted by bohead
Hi Ladzio, so I've completed and assembled the boards. But my question is, since the resistors can be put before or after the leds, instead of using a PWM, can't I just find an appropriate resistor to control the amperage driving the leds,thus making them dimmer? Is there a reason why you didn't use this for your setup in the first place? Just place a resistor (330 Ohms for example) on the ground line which would power up the LEDs when lights are on? (not the ground for brake)
Hey Ladzio,
What value resistor do I use for the Brake Boards while using the regulators at 10V?
I need to replace the 33 OHM resistors with 1 OHM resistors, and the 66 OHM resistors with 39 OHM correct?
I ran it through wizard, I'm just not sure if I entered the correct information in the right way. Thanks man.
I do not know how far you guys are but here is a last bit of important info, maybe you already researched it on HIDPlanet.
See this schematic...
A round element to the left from LED board is transistor. It acts as a switch. When it is not active, the charge has nowhere to run but back to PWM, which switches ground on and off (in my case, using Valleman PWM) and thus does not let LEDs to fully power up. However, when it is powered (when you hit brakes, follow wirng to see) switch locks in and connects negative from the board to a solid ground and thus LEDs can fully power up and light up bright, serving as brakes.
1) On the schematic you have on couple posts up, there's a volt reg. before PWM. Which one did you use? I don't see why you put a volt reg. before PWM when you put programmed LM317T before all the brake LED boards.
What schematic do you refer to, right above your post? Could you post it so it would be clear?
2) Did you use diodes on your circuit?
Yes, N4001 I believe, you can see them in the shcematic above your post.
3) Which resistor did you use before TIP31 transistor?
270 Ohm Resistor
270 Ohm Resistor
Hey Ladzio. Must say I'm loving these tails and getting a lot of attention from random people asking me where i got them. Anyway, when I step on my brakes the parking lights go on. What do you think it can be?
Here is a pic of the connectors which are connected correctly...
And heres a pic of the wires that I spliced into...
The red wire from the control box is spliced into the red/blue wire. The white wire from the control box is spliced into the red/green wire. And the ground wire from the control box was spliced into the parking light wire at first and then grounded to a bolt to try and fix the problem. I thought that the problem was that the ground was spliced into the parking light ground. But I dont think so anymore because I switched the ground.
When you step on the brakes, parking lights go on:
1) Specify what parking lights: all, front, your dash, or only small bulbs on sides?
2) I have a feeling in that control box I might have forgot to put one diode, but I'll be able to figure more once I get answer to point 1.
When I step on the brakes, all my lights go on as if I have turned on the parking lights with the stalk. The front corner lights, the tail lights, and all the interior lights go on.
1. Next, when did you first notice that, as soon as you installed the LED tails, or maybe you did some rewiring?
2. Try to install your stock tails and see if the problem persists.
Let's try to narrow down the cause.
Try to install your stock tails and see if the problem persists. This will really help to see whether control box is the problem or something else.
I never had this problem before with my tails so your cooperation is essential
I was thinking things over and I think I know what the deal is. I am coming back to CT for summer vocation after memorial weekend and we might meet up some time after that and troubleshoot this sucker.
For those that are reading this thread to get a clue how to make own LED tails set here is what the problem potentially is:
As you know PWM is needed to dim LEDs so that they would light up with intensity of parking lights. Thus, when you flip your parking lights switch on you send power to PWM (we tap into parking lights wire for that) and PWM then send power to tails, finally "charge" going back into PWM "ground wire" and from PWM into ground wire that we tap into the harness (see description above for how PWM works).
When we hit the brakes, brakes wire gets charge at which point we split it into to paths. (1) brake wire we tap into parking lights wire (with current limiting diode N4001 in between so that power runs from brakes to parking only) in order to light up LEDs; (2) brake wire we tap into transitor that is connected to the solid ground, thus activating a bypass around "switching" ground of PWM to teh solid ground in order to let LEDs fully light up.
The problem I believe is that when we hit brakes and send current into the parking wire, not only it activates PWM but also send current throughout the whole car parking light system. To remedy this we just need to install another N4001 current limiting resistence to direct current flow to PWM only.
I hope this makes sense, I will draw a diagram after I make sure this solution works.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
